A/C and smog delete questions
Car: 1988 Pontiac Firebird Trans Am Vert
Engine: 5.0L TPI
Transmission: 5-Speed
Axle/Gears: 3.08
I have done a lot of research on this topic and I believe that I am ready to put in the eliminator pully and pull the smog pump. I also want to pull the heat at the same time. I am going to get the longer serpentine belt and re-route it as madmax did in his tech article. I plan on having a local shop discharge the system before I start pulling stuff out.
I was wondering if someone could take this picture in MSpaint and circle all of the parts that I should be able to pull off. I think that I know what they all are, but I really want to be sure. I figured that I would do this now because I have a set of headers coming in a couple of weeks and I would really like the install to go smoothly. (Wishful thinking?)
Any helpful suggestions would also be appreciated..
ambainb
Apr 25, 2016 09:21 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
BikeFarm
Aug 11, 2015 11:35 PM
