Is this surprising?
Old Jun 20, 2004 | 07:33 PM
ss85tadude's Avatar
Car: 85 Trans Am
Transmission: 700-R4
Is this surprising?
I just took the valve covers off of my L98 engine that I am going to get freshed up when I get the money. When my dad took a look at it he was surprised that he could still see the bare metal (silver part circled in pic) What does this tell you? This engine has been sitting for about 3 years also.
Old Jun 20, 2004 | 07:39 PM
ss85tadude's Avatar
Car: 85 Trans Am
My dad was also surprised to find out how clean it was inside. We are thinking all this engine needs to run good are new piston rings, hone the block and heads, replace valve seals and seats, and a new cam. Anything I am missing? And how much do you think it should cost?
Here is another pic:
Old Jun 20, 2004 | 09:18 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
How many miles does it have on it. I would chanced the fluids, prime the oil pump and fire it up. It looks clean to me. You do not need to change the cam or any part for that matter if it is not ruined. You could follow the engine break in procedure if the motor ran perfectly before it sat.
Old Jun 21, 2004 | 12:48 AM
ss85tadude's Avatar
Car: 85 Trans Am
Thats the thing, I dont know the history behind this motor. And I buidling this for a reliable street engine, So you dont think any thing has to be replaced? Not even rings after sitting that long?
Old Jun 21, 2004 | 01:14 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Since its been sitting so long, youll also want to throw a couple of tablespoons of oil into each cylinder and turn it over by hand to lube the cylinders up after youve primed it. Maybe even throw some clean oil over the rockers.
Old Jun 21, 2004 | 08:26 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
No you will be fine. One of my dads work trucks sat for over 8 years at one point in its life and it runs fine now. No hard parts should go bad. Oil, gaskets, and fluids are what can go bad.
F-body-fan
May 4, 2026 09:42 AM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
codeysabatini
Exterior Parts for Sale
Sep 24, 2015 05:40 PM
buckeyecelt
Sep 24, 2015 05:50 AM
dbrochard
Sep 19, 2015 08:13 PM
