Dash Gauges
Old Apr 18, 2001 | 12:39 AM
pookey's Avatar
Dash Gauges
I have A 305 TBI and want to know if the temperature sesnor located on the top front of the engine? I have 1 person telling me yes, and 1 says no. Or could that be the oil pressure gauge?
Old Apr 18, 2001 | 01:28 AM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
The one in the intake manifold? That's the Coolant Temperature Sensor. I'm not sure if it controlls the gauge or not, but I know the ECU uses it.
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Apr 18, 2001 | 12:40 PM
Jza's Avatar
Jza
The one for your gauge in on the side of the motor between #1 and #3 cylinders.
Old Apr 18, 2001 | 02:14 PM
pookey's Avatar
If the temp gauge is between 1 and 3, where would the oil be?
Old Apr 19, 2001 | 07:28 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Right above the oil filter...
KAM
Old Apr 19, 2001 | 09:07 AM
82resto's Avatar
Hmm.. so that's what I disconnected the other day....
So, between the 1 and 3 is the sensor that goes to the dash? Then the one on the intake manifold is just used by the ECM right? So if I plugged that hole, since I have no ECM, it wouldn't make any difference, right?
Jon
82 Trans Am
Original 134,000 mile LG4
Holley 600 cfm carb, Weiand Stealth Intake manifold, no smog equipment, Hooker headers are in a box next to the car, and the cat back is on the way... now all I need is that elusive Y-pipe....
Old Apr 19, 2001 | 09:39 AM
Enkil's Avatar
I thought the one the ECM used was between 1 and 3, and the one that the temp gauge used was on the intake...
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Bubbajones_ya
Jul 6, 2024 08:32 PM
MantyZ28
Nov 8, 2015 06:54 PM
TrevinE
Sep 14, 2015 03:20 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
86IROC112
Sep 11, 2015 04:04 PM
