I need to the port size so i can order header gaskets, Know ones it seems?
Old Apr 19, 2001 | 09:47 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
My ports for my header gaskets, do I need a 1.50 by 1.50 or a 1.36 by 1.36, the motor is a gm replacment 350 and the headers are for a 305 lg4 and they are 1 5/8, I want to use the earls gaskets. thanks
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Apr 19, 2001 | 09:52 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
On my L98 I used Felpro 1444 1.38 X 1.38
Old Apr 19, 2001 | 09:54 PM
checkeye's Avatar
I get the smaller ones, then cut them out to match the exhaust ports. I have found that when buying the larger size there is very little material between the 2/4 and 3/5 exhaust ports. Seems like they blow out quicker between the ports with the bigger ones...
Old Apr 20, 2001 | 06:56 AM
BLACK Z's Avatar
Car: 86 Z28
It is unbeleivable that summit can't tell me which ones, pace parts and scoggin dickeys are not sure. You figure they sell the motor and the parts you think they would know. Thanks guys for your help, does anyone else have anything to add?
Old Apr 20, 2001 | 09:59 AM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Only one way to do it, MEASURE the ports. That way you are definately sure you have the right gasket size (same goes for intakes).
George P. Lara
1984 357 T5
1994 LT1 M6
SCCA, SCFB, SC3GFB
Old Apr 20, 2001 | 12:39 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Summit and autozone said felpro 1444 for my car which are 1.38 X 1.38. Theres the answer.
Old Apr 20, 2001 | 09:00 PM
BLACK Z's Avatar
Car: 86 Z28
But if the headers are 1 5/8, wouldn't the 1.50 by 1.50 still be to small, considering that that is only inch and a half?
1992 Trans Am
May 10, 2023 07:19 PM
toronto formula
Nov 10, 2015 06:17 AM
hectre13
Sep 8, 2015 03:38 PM
NinjaNife
Aug 23, 2015 11:49 AM
knight72
Aug 10, 2015 09:32 PM
