engine is grinding
engine is grinding
it sounds as if someone is sharpening a knife on a bench grinder in my engine. at first i thought it was belts squeling, but i sprayed them down and its still happening. happens in all gears at all times, gets faster as engine revs. anyone have any help as to what this is, and whether or not i need a new engine.
thanks
thanks
Car: 4
Engine: 6
Transmission: 5
Take the belt(s) off, and see if it still does it.
ICON Motorsports
ICON Motorsports
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
When My alt. went bad and the front bering collapsed it made that sound but it actually still worked for a while ((I was out in the middle of no-where))and I made it all the way home.
just a thought...make shure that everything is ok and the blades on the alt fan aren't rubbing on the housing...
worth a look
Hecubus
Check out my new site http://www.geocities.com/hecubus91
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/Nos Wet Plate System currently ~200hp shot/ 155lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel,Air-fuel, voltage & Oil Press Guage's/MSD 6al/ Blaster coil/ Optima,Yellow top batt.
"I spent all my money on race cars, beer, and Broads... The Rest I wasted"
worth a look
Hecubus
Car: 91 z82
Engine: 5.0
thats exactly what mine sounded like !!!!
did you check that????
Hecubus
Hecubus
i did. the fans not even running, the belts arent making any noise. its a LG4 & when i crawled under it sounded like the noise was coming from the bottom of the endine towards the front. now if its what were thinking it is, is it fixable or do i need a rebuild, and how long do i have before it totally stops? thanks!!!
p.s. it doesnt seem to have lost much if any power.
