Combo question
Old Jul 26, 2004 | 10:32 PM
jc265's Avatar
Car: 89 RS with 350
Engine: 5.7
Transmission: auto
Combo question
I'm saving up money to get some stuff for my car and was wondering how much hp i could get outta this stuff...
*88 z28 engine
*Magnum 270H Hydraulic Flat Tappet Camshaft & Lifter Kit
Lift: .470''
Duration: 270°
RPM Range: 1800-5800
*Flowmaster Replacement Mufflers - 1982-92 Camaro Z28/Firebird Trans Am: 80 Series, 2.5''In/2.5'' Dual Out - 80 Series
*Edelbrock T.E.S. Headers - 1986-90 Camaro/Firebird 5.0L/5.7L TPI 3'' slip-on single cat.
*Hipsters ATD Powerglide Transmission - Trans with Turbo Input
*GM Performance Flywheels - FYLWHEEL 168TH 1PC 86-UP
Any ideas on hp with those mods?
What other "cheap" things could/should I add on?
Old Jul 26, 2004 | 10:43 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Whats a 88 z28 engine?
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
To add probably +20hp over what the stock motor makes.
Old Jul 26, 2004 | 10:50 PM
jc265's Avatar
Car: 89 RS with 350
Engine: 5.7
Transmission: auto
only 20ish HP added to the 235ish hp the motor puts out? cant be right...the exhaust says 30 hp alone from JEG's site
But I dont know much about this stuff tho..
those mods are about 1600 bucks from jegs
Old Jul 26, 2004 | 10:53 PM
jc265's Avatar
Car: 89 RS with 350
Engine: 5.7
Transmission: auto
guess i did not word it right..
the complete motor out of a 1988 Z28
Old Jul 26, 2004 | 11:09 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
What engine is it there are many different engine that were available in 88. You will not get 30 hp from exhaust, only when your making 400hp will exhaust add 30hp.
Old Jul 26, 2004 | 11:53 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
What size is it? 305 or 350 and if its an 88 it should be a roller engine so I would get a roller cam if I were you. Such as the Lt1 cam or maybe the Lt4 hot cam. Also you might want to make sure whatever heads you have can handle .470 lift. I think with a decent cam and a full exhaust(headers, high flow cat or no cat, and 3'' catback) you will gain about 30hp or so depending on what heads and what induction you have. It will be a noticable difference. But if you have crappy heads and crappy induction you wont be able to take advantage of the cam and exhaust. Good Luck.
Old Jul 27, 2004 | 05:59 AM
jc265's Avatar
Car: 89 RS with 350
Engine: 5.7
Transmission: auto
Its a 350. Sorry guys, never been too good with this stuff.
Is there anyone who spent around $2100 and has a good setup? Thats my budget for my project right now, labor not included. Any ideas on the max hp I could get outta $2100, maybe going a little over?
Thanks for your help
Old Jul 27, 2004 | 01:50 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
With 2100 I could go build a +/- 350 hp engine. You have to do all the work yourself and be one hell of a deal finder.
With 2100 you can build a nice engine, at least around here.
But if I used my connections.. probably alot more.. i get **** for wholesale
Old Jul 27, 2004 | 08:52 PM
jc265's Avatar
Car: 89 RS with 350
Engine: 5.7
Transmission: auto
ok, so with 2100 bucks ontop of the 1988 5.7 Z28 engine..i could get 350ish HP outta my engine (labor not included) that sounds good to me lol
Old Jul 27, 2004 | 10:08 PM
IROCaholic's Avatar
Car: 89 Camaro RS
If you already have the motor and $2100 to add to that you can easily achieve 350hp. If its a roller motor(which it should be if its from an 88 z28)I would go with the SDPC vortec kit with the RPM intake and heads that handle .550 lift. Then add an Lt4 hot cam or a simular roller cam. You will make about 400hp at the fly with that combo and a full exhaust system.
Old Jul 27, 2004 | 10:15 PM
jc265's Avatar
Car: 89 RS with 350
Engine: 5.7
Transmission: auto
Any good places to get these things? Should I look @ online places like Jegs and Summit?
Old Jul 27, 2004 | 10:19 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
http://www.sdpc2000.com
Browse around there and you will find the parts listed above.
Old Jul 27, 2004 | 10:20 PM
jc265's Avatar
Car: 89 RS with 350
Engine: 5.7
Transmission: auto
they offer reasonable prices?
edit:
http://www.sdpc2000.com/cart.asp?act...2172&pid=89540
is this what i should be looking at?
LT4 Hot Cam SBC GM Hydraulic Camshaft Kit
Price: $499.95
Part # 12480002
I will need the kit, not just the cam, correct?
ydnar417
Sep 23, 2015 05:57 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
