MY TEMP GAUGE??
MY TEMP GAUGE??
Please help me, i just got a 87 iroc 305 tpi,the temp gauge worked fine..till i unhooked both fan relays..then i noticed my gauge stuck in the 12 o'clock position.I have change my sensor(in front head) and the 1 between #1 and 3 plugs , but it still wont work, and does anyone know if the sensors yellow wire should light up a test light?? mine wont, any help would be awesome......
I forgot to mention that the reason i unhooked my relays is cause 1 fan(got dual fans) ALWAYS comes on (as in when the key is turned) so i unhooked the relays and switched them and same problem), i am really perplexed on this 1
