180 Amp Alternator
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
180 Amp Alternator
my car now has underdrive pulleys and horribole charging problems. aside from the fact my alternator may be going bad too i need a new one and wont go less than 180 amps but i cant find one anywhere. jegs and summit stop at 140 and i cant find anything bigger can someone point me in the right direction. and what specific type do i need? is it the gm one wire hook up?
Car: 1991 Z28
Engine: 383
i dont know if ive heard of an over driven pulley. i had the crank and alt underdrive pulleys but had to switch back to the stock alt pulley because of the severe charging problems. i still need a bigger alt, im sure mine isnt tip top anymore but just cant find a 180 amp to fit.
Car: 1991 Z28
Engine: 383
as far as i konw ive got the stock 105 amp alt that came stock on the car. the underdrive pulleys i know really nothing about, bought them used on here. actually a waste of money...
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Originally posted by CamarosRUS
the underdrive pulleys i know really nothing about.......actually a waste of money...
check out alternators.com i have a new delco 140 10si in my car, works great!
as far as pulleys go, take your current pulley to a alternator rebuil shop and they should be able to give you a smaller one. many severe duty GM applications use smaller alt pulleys.
Car: 82z28
Engine: 406
Transmission: th350
I had my 200 amp one built by www.4alterstart.com
Depending on the ratio of the pulleys, by switching back to the stock pulley you may have slowed down the alternator rotation.
I know my march pulley setup was smaller for the crank and waterpump, but it was a larger pulley for the alternator to make up for the smaller crank pulley. It keeps me above 12v at idle (usually 12.3-12.4), and as soon as I bring the rpms up above 1000rpm it shoots to 13.8-14.2v. Still not optimal, but definately keeping a charge in the battery.
Measure the diameter of the drive pulley (crank) and divide that by the diameter of the driven pulley (alternator). Then increase the size of the driven pulley until you get a ratio close to stock. That should get the alternator RPM's back up.
Oh, another issue to worry about doing the pulley intermixing. The backspacing may be different between stock and aftermarket, making you throw belts. IIRC my new pulleys stick out approx. 1/8" further than stock ones. Probably to make them more universal.
Good luck with it
Good luck with it
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
Guess you haven't ridden a 10-speed bike in awhile, eh?
raymondandretti
Sep 27, 2015 06:43 PM
