TPI to Carb
Old Aug 16, 2004 | 08:41 AM
87camz28's Avatar
Car: 1987 Camaro Z28
Engine: 5.7L, L98 slightly modified
TPI to Carb
I am building a new engine for my 87 Camaro that was originally a TPI car. The high performance engine I am putting back in the car is going to have a carb set up. I have already gotten a HEI distributor from a donor 79 Camaro. I wanted to make sure I had the wiring correct. Thick pink wire coming from the fire wall plugs into the BAT "+" terminal and the white wire from the fire wall plugs into the tach terminal. Is this correct?
Thanks in advance!
Old Aug 16, 2004 | 10:26 AM
Chris's 85z's Avatar
Car: 85 Z
Engine: 383
You got it!
Old Aug 16, 2004 | 11:01 AM
87camz28's Avatar
Thanks, I thought that was correct.
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
