cooling problem after tempswitch swap
Old May 14, 2001 | 11:00 PM
Stell1579's Avatar
my LB9 has the duel fans. i changed the sensor on th eblock to the jey one that has a 200on 180 off. i am also running a 180 thermostat and i have the tranny on a cooler
for some reason once the fans come on they dont wanna go off EVER. if i am doing 70 crusing they will go off but if i let it idle they stay on and wont go off. the temp of the engine comes down alot but fans dont go off. could it be the 180 thermostat is closing to early? if so maby a 170 would do me better is 170 thermo and the fans on at 200 bad? also am i gonna reach closed loop when crusing on the highway? with a 170 especially in the winter? could i be my coolant? its mostly water right now. about 65/35 (65% water)
thanks
-Stell
1988 IROC-Z 305TPI MINT!!
Mods= Accell SuperCoil, MSD 6A, Ported Plenum, No MAF Screans, K & N, SLP AirFoil,180 Thermostat+ Temp Switch, Relocated MAT, Cold Air, Hooker Aerochamber Catback,MSD Ignition wires and a few other misc goodies
1988 Pontiac Trans Am. 305 TPI Beyond MINT Condition. Dynomax Catback
http://stell15790.tripod.com/cars.htm
Old May 14, 2001 | 11:13 PM
MikeC.86Roc's Avatar
What is your operating temp? Highway vs. In-town? I am running a 160 stat with edelbrock water pump and my temp will hit 210-220 occasionally on hot days in traffic. My mix is 50/50 antifreeze coolant.
Old May 14, 2001 | 11:35 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Ya...you need to get a lower Tstat, 180 is too close for the fan switch you chose. I'd use a 170 with it.
Old May 15, 2001 | 12:54 AM
JoeIROC's Avatar
Also, shouldnt you have at least 50% antifreeze? The only reason I add that into the mix (no pun intended) is that it may affect how fast (or slow) the coolant temperature changes. (i.e. specific heat of the coolant)
FYI: specific heat = amount of heat needed to raise 1 g of a substance by 1*C. Higher SH means more heat is needed to raise the temperature of the mixture. For a radiator, this translates into how long it takes to heat up, or cool down the mixture. The only thing is, im not sure how adding antifreeze to water changes the SH. (by definition, water has a SH of 1.0)
As an example, aluminum has a very low SH. It gets hot fast, and cools quickly as well. Notice this next time you take super-hot aluminum foil off a baked potato. The foil will cool down to room temp almost immediately.
Had enough of this chemistry lesson?
Joe
86 IROC TPI 305
700-R4 with Trans-go shift kit
K&N Air filters
Dyno-Max cat-back
Summit tranny cooler
CEI throttle enhancer chip
[This message has been edited by JoeIROC (edited May 14, 2001).]
Old May 15, 2001 | 01:25 AM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 8Mike9:
Ya...you need to get a lower Tstat, 180 is too close for the fan switch you chose. I'd use a 170 with it.</font>
...or install a temperature switch with a lower differential. The AutoMeter 3246 has settings of 203° on temperature and 187° off. I've been using one for two seasons with a 180°F Delco stat with no such problems. It has the standard ½" NPT male body and two ¼" spade terminals for connection (not internally grounded). They are about twenty bucks at most speed shops.
Later,
Vader
"Fear is how I fall, Confusing what is real..."
Adobe Acrobat Reader
Old May 15, 2001 | 05:40 AM
custman87T/A's Avatar
I have the jet switch also in my car with a 180 thermo and no real problems. The switch is 200on and 185 off not 180. So you shouldn't have a problem with the fans not turning off although it does take a while to come down to temp at idol. I borrowed a lazer thermometer from a friend and found mine is comming on at 204-206 and off at 183-185.
Old May 15, 2001 | 01:45 PM
dude12387's Avatar
I just installed the JET fan switch two days ago......and i dont have that problem......but now my temp. gauge doesnt work at all.....any ideas on what i can do to fix that?
"When something breaks, it gives me an excuse to replace it with a performace part!"
1988 GTA
TES headers
Flowmaster exaust
TB airfoil
165 Tstat
K+N's
JET chip
kenwood head unit, xplod amp, poineer 3 ways
weird rattling noises
dying 350
crappy paint
700R4 on its last leg
hood that won't open
Old May 15, 2001 | 01:53 PM
Bort62's Avatar
Wait, IIRC, the Spf for Water was 4.6 Or something....
Or is that 4.6 Joules to Raise 1 gram 1 Degree C, but yeah, that would be 4.6....
Hmm, I cant seem to find My damn AP chemestry book from the HS days.
lots of Calculus, and Physics, but No Chem ;(
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Reader's ride -&gt; My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
ZMWojnar
Brakes
May 12, 2019 10:43 PM
nuggie
Aug 25, 2015 01:27 PM
theurge
Aug 21, 2015 12:46 PM
Bryan F
Aug 18, 2015 02:28 PM
sreZ28
Aug 14, 2015 07:48 PM
