What can I do to get my temperature down?
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Okay it is getting hot around here now. My A/C works great, but my car overheats when it is on. I will sit at about 210* when i'm going about 40-55 mph, but any faster and it starts overheating. (I have no airdam). And when I sit in traffic it will overheat. I know I need an airdam to fix the high speed overheating problem, but what can I do about sitting still. Would an electric can (or 2) and an aluminium radiator solve it? What can I do until I get the cash for this stuff? coolant flush?
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
1983 Firebird
TH700R4 Auto
Small Block 400
I installed a Single electric Fan out of a V6 Fbod, and Have it wired on all the time out of sheer lazyness.
I cant get the Car to Run above 140~ ish, Wich may possibly be causing me atomization problems.
But that should Cool you Down alot
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Car: 1988 GTA
Engine: 5.0 TPI
Heck I can get e V6 electric fan easy from a bone yard!
1983 Firebird
TH700R4 Auto
Small Block 400
[This message has been edited by Ward (edited May 13, 2001).]
1983 Firebird
TH700R4 Auto
Small Block 400
Car: 1988 GTA
Engine: 5.0 TPI
Bort what type of radiator do you have? Aluminium? And will it run at 140 wit hthe A/C on?
1983 Firebird
TH700R4 Auto
Small Block 400
1983 Firebird
TH700R4 Auto
Small Block 400
Car: 4
Engine: 6
Transmission: 5
Either replace the fan clutch, or get an electric setup. If you get a new fan clutch, make sure it's the "thermostatic" ($$$) kind not the "centrifugal" (cheap POS) kind... the thermostat is clearly visible, it's a coil on the front face of it.
Whatever you do, don't get a flex fan and a spacer, that's a step backwards in cooling and will cost you many, many HP.
ICON Motorsports
ICON Motorsports
Ward, its the stock Radiator.
And what AC ?
lol
But I did drive over the grape vine in 100 degree weather, and it never got over 200.
And what AC ?
lol
Car: 82 camaro SC
A GOOD flex fan would work great--cooling much better than a stock fan with a new clutch and taking less HP when the engine is at higher rpm. I run 190 with the A/C on in traffic. 185 down the highway. Make sure you fan clutch is kicking in when it the radiator gets hot(should be a loud roar).
Wrong timing, low idle rpm, and lean idle are some other possibilities.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
82camaro
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
My engine was overheating with the a/c on especially when at a stoplight. I installed an extra electric fan and now my overheating problems with the a/c are gone. I also went with an aluminum radiator. I am running without a termostat but I would not recommend that if you have your puter still hooked up to your engine.
Big 454 72 Chevy Nova
383 86 Camaro Z28
10.5:1compression 186 casting Heads,234dur.488lift exh&int,Edelbrock performer intake, Holley750 vac.sec 400 crank,flat top pistons,edelbrock valve springs and lifters,tranny shift kit,2500 stall converter. Will install 3.73's later on and might go with a more aggresive cam.As of 4/01 added Hooker Headers,2.5inchpipes with 40 s. Flowmasters.Ignition upgrade include: MSD Coil and MSD module.
383 86 Camaro Z28
Car: 1988 GTA
Engine: 5.0 TPI
Yes its my stock radiator. And Ill shoot myself before i ditch the A/C. It easily gets to 100 degrees outside here in Texas. I checked at autozone, a new alum raidator is $139.99. Ill probalby go with that and a solid fan mount.
1983 Firebird
TH700R4 Auto
Small Block 400
1983 Firebird
TH700R4 Auto
Small Block 400
