Closed loop with new thermostat
Old May 15, 2001 | 09:04 PM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
I've read how many of you have switched your thermostat to a 160* or 180* in an effort to cool your cars better. Doesn't this "fool" the car's computer and not allow itself to go into closed loop operation? If the computer thinks that the operating temperature should be so that the thermostat fully opens at 195*, and the lower temp thermostat is installed, what does it mess up?
Old May 15, 2001 | 09:18 PM
Enkil's Avatar
I think the computer needs to see 160* before it goes into closed loop.. I'm not positive though. For non computer-controlled cars this isn't really an issue. However, you'll generally get better fuel economy if your car goes into closed-loop mode.
Now, you can easily modify the computer chip to suit whatever thermostat you put in.
However if everything on your car is stock, and you put a 160* t-stat in, you'll likely run into several drivability issues.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old May 16, 2001 | 01:07 AM
Omar's Avatar
Closed loop is around 105.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old May 16, 2001 | 01:58 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
You'll want to get Hyepertechs Thermomaster chip. It is specifically programed for low temp stats. Trust me on this one.
Old May 16, 2001 | 12:30 PM
GiddyUP305's Avatar
Engine: turbocharged 4 cyl Dohc
Transmission: 5 spd sentronic
i just recently installed a 180* stat on my bird i've noticed it still runs @ about 220* is there something wrong or is this a normal operating temp?
<A HREF="http://www.fbody.com/members/305inmybird/index.htm" TARGET=_blank>WEB SITE HERE
</A>
html
Old May 16, 2001 | 01:00 PM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Omar:
</font>
Actually, the ECM can enter closed-loop mode at 104°F, but there are many other temperature-specific functiions controlled by the ECM, some of which do not get enabled until 176°F is reached. Thsi, of course, is with a stock EPROM.
Later,
Vader
"Fear is how I fall, Confusing what is real..."
Adobe Acrobat Reader
Old May 16, 2001 | 02:37 PM
Ovrclck350's Avatar
I have a Stage 2 Jet Chip and was getting around 15-16 MPG with a 160. With the 180 I have now I'm getting around 20-23 depending upon my driving. That 20 is half highway, half foot to the floor city driving.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
