Click Click
Old Sep 30, 2004 | 04:33 PM
1-MEAN-T/A's Avatar
Car: 1986 Trans Am
Engine: V8 305 LB9 5.0 T.P.I
Transmission: THM 700 R4 Auto
Click Click
Hey guys, fist time posting in this forum, wish i didnt have to...Anyway, let me start from the beginning. My car had some problems a while back with hesitation and stalling.I got that fixed by getting a new electrical harness for the computer, m.a.f. sesor and o2 sensor. the car ran great except......all of a sudden now if i hit the gas just a little harder than normal acceleratrion i get a clicking sound. Its loud enough to hear inside the car.i was told to use higher octane gas. ihave for about 2 mos. now and still the clicking.The clicking only starts when i hit the gas hard like i sated above when the car is warm. IN the morning when the car is cold its a champ. Another thing is like a thumping heard under the car and i can feel it in the pedal? i kno, my car is a piece of crap but who da thunk that a car with less then 60,000 miles would have so many problems? anyway any help would be greatly appreciated and any questions to help u help me, ask
-Adam
Old Sep 30, 2004 | 04:54 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Click Click
Originally posted by 1-MEAN-T/A The clicking only starts when i hit the gas hard like i sated above when the car is warm. IN the morning when the car is cold its a champ.
Did you advance you're timing any? Retard it some. When engines get warmed up (especially when they overheat), the dreaded spark knock will become prevalent (if too far advanced).
Originally posted by 1-MEAN-T/A Another thing is like a thumping heard under the car and i can feel it in the pedal?
Thumping? When? When you hit the gas, or when you shift the gears (or both)? Or is it constant? If it's a loud thump every now and then, check you're torque arm.... it might have disconnected from the top of you're tranny, and is now hitting you're floor board.
Edit: Spelling Correction
Old Sep 30, 2004 | 07:28 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
the thumping, if it occors under accelearation could be the u-joint hitting the tranny tunnel bacause of a broke tranny mount, if it is I reccomrnd getting an energy suspention's one, they have an internal locking device in them to prevent it from happening again
Old Sep 30, 2004 | 07:37 PM
sellmanb's Avatar
Car: '86 Berlinetta
as-per the clicking problem, did you do a spark plug change ? if so, did you gap the sparkplugs to .035? if not you may wish to take out the plugs and try it again.
Your thumping is not related Check the mounts and such like suggested above
Old Sep 30, 2004 | 07:47 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Sounds like spark knock and tq arm mount to me.
Do as stated above.
Old Sep 30, 2004 | 09:05 PM
1-MEAN-T/A's Avatar
Car: 1986 Trans Am
just to clarify a few things since my first post was just me spilling out my problems. I did recently have a tune up(a very bad one) and i now that i think about it, the clicking did start soon after.
as for the tranny mounts, i just had them replaced not 2-3 mos ago. but (this may sound dumb), this could be y the car still jumps when i shift from park. The thumping only happens when i accelerate slowly and i feel it in the pedal. also, how hard is it to check the gap? i know what agapper is but is this somehting a kid that's not too good with engines can do? sorry for the constant annoyance but i love this car and i want to keep it to enjoy it. Thanks for any help,.
-Adam
Old Sep 30, 2004 | 11:17 PM
sellmanb's Avatar
Car: '86 Berlinetta
if you only feel the thumping when you're on the brake... does it come FROM the brake, or the floor pan? If from the brake then you probably have a warped rotor. As per the gapping, if you get a gapper (Schucks gave me one for free lol) and put your spark plug to it you will see almost immediately how it works.
Old Oct 2, 2004 | 12:05 PM
1-MEAN-T/A's Avatar
Car: 1986 Trans Am
not when i hit the brakes, when i hit the gas slowly....
Old Oct 3, 2004 | 01:08 PM
sellmanb's Avatar
Car: '86 Berlinetta
make sure none of your plug wires are touching manifolds or headers, or being burnt up. if you were running off of 7 cylinders you wouldnt really feel it when racing (though you'd lose power obviously), but at a slow pace acceleration you would feel it more.
Old Oct 3, 2004 | 02:26 PM
Originally posted by 1-MEAN-T/A I did recently have a tune up(a very bad one) and i now that i think about it, the clicking did start soon after.
Who did the tune up, and did they rotate the distributor any? It sounds like you're timing is a little too advanced.
Double check both you're oil level and pressure while you're at it... and have someone re-adjust you're rocker arms (clicking can come from their as well). However, if the clicking is effecting performance, it's more than likely you're timing.
Originally posted by 1-MEAN-T/A as for the tranny mounts, i just had them replaced not 2-3 mos ago.
The transmission mounts have nothing to do with the torque arm hitting the bottom of you're floor pan (if it is in fact that, that is). The torque arm bolt is directly opposite of the catylitic converter bracket bolts (on top of the tranny). Check and see if it's not connected, it takes two minutes.
Edit - What part of Jersey are you in?
Old Oct 3, 2004 | 02:40 PM
Re: Click Click
Originally posted by 1-MEAN-T/A ... I got that fixed by getting a new electrical harness for the computer, m.a.f. sesor and o2 sensor.
By the way.... did they re-set the ECM after installation, and are you getting an SES (service engine soon) light?
I almost forgot you had TPI, as this happened to me awhile back. After changing to better plugs, I forgot to gap them properly.... and she was knocking like crazy (felt like limp home mode). Re-gap the plugs before you do anything else.
Old Oct 3, 2004 | 09:32 PM
1-MEAN-T/A's Avatar
Car: 1986 Trans Am
As for where i am in jersey, piscataway and yes my service engine light is on.It goes on right after the clicking starts. I do not know if they reset the ecm, how would i? And i will have the spark plugs checked....THanks for all the help guys, anymore suggestions, im open....
-Adam
Old Oct 6, 2004 | 08:11 PM
As for where i am in jersey, piscataway and yes my service engine light is on. It goes on right after the clicking starts. I do not know if they reset the ecm, how would i?
If you frequent Raceway Park, send me a PM.... as my cousin has his own shop, and he could check it for you, if you'd like. My guess is that it's somewhere in you're ignition, or quite possibly the ESC (electronic spark control) module itself.
If you didn't diconnect the battery yet, disconnect it, and let it sit for about ten minutes. This will re-set the ECM, and erase any stored error codes that might have been accidentally triggered.
RS Reaper
Oct 17, 2018 07:52 PM
Linson
Oct 1, 2015 09:50 PM
mcbitchman
Sep 29, 2015 12:32 AM
sahlomonic
Sep 20, 2015 07:15 PM
