Now the car don't start at all??????
Old May 13, 2001 | 04:51 PM
camaro 22's Avatar
I think it's the fuel pump, but i just wanna make sure. nothing is comming out of the injectors at all now and i know i have a full tank. when i turn my key to the on position, i don't hear it kick in at all like i do on my other camaro. do you think that's what it is? how much is the part, and how hard is it to replace? should i just take it to someone? hope you can help.
Old May 13, 2001 | 08:41 PM
camaro 22's Avatar
ok, i sprayed starter fluid into it and it started right up and i drove it around. and even after i turned it off it started up, but took a little long again. what could be the problem? a clogged fuel filter maybe? dirty injectors, even though i put fuel injector fluid in a few weeks ago? i hope someone can help.
Old May 14, 2001 | 08:43 AM
camaro 22's Avatar
anyone know???
Old May 14, 2001 | 06:57 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Souns like the fuel pump relay....
Once the engine is running the fuel pump gets its power from an oil pressure switch; that's why it will start on ether and keep running. It needs the relay for starting though.
ICON Motorsports
Old May 14, 2001 | 08:05 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Yeah unplug the relay and apply 12v to the second terminal from the right (I'm not absolutely sure, but mostly sure that's the one) if you don't hear the fuel pump hum I'd change the relay before looking into other things.
Old May 15, 2001 | 08:31 AM
camaro 22's Avatar
where is the relay at? thank you guys for your responses.
Old May 15, 2001 | 10:01 PM
camaro 22's Avatar
ok, i put a new relay on, and it didn't change anything, along with spraying the carb with cleaner and putting the good gas in with fuel injection cleaner. it's still cranking for ever to start, and now and then while driveing and idleing, the exhaust has alot of smoke comming out of it. not all the time, but sometimes, with a foul odor. Please Help. Could it be the fuel filter?
Old May 16, 2001 | 10:40 AM
camaro 22's Avatar
anyone else wanna take a crack at this?
Old May 16, 2001 | 10:59 AM
Stoopalini's Avatar
Have you changed your fuel filter yet? It could be bad causing flow problems.
If that's not it, It sounds like your carb might need rebuilding.
It could be your fuel pump? ..... but I don't think it would keep running after it start up if the fuel pump was going out.
Has it ever died on you while driving around?
Thomas.
1992 RS Camaro - Red
305-TBI/5 Speed Manual- 3.08 geared rear
1.6 Roller Rockers and Cam / Adjustable Fuel Regulator with high flow pump / Open Air K&N Filter / TBI Spacer / ADS Super Chip & custom burned Off-Road Only chip
Headers - Flow Master - dual chrome tips
adjustable Coni shocks & struts
Old May 16, 2001 | 05:09 PM
camaro 22's Avatar
My next thing to do was the fuel filter. I hope it's just that, and nothing major. Thanks for your response.
Old May 16, 2001 | 05:13 PM
camaro 22's Avatar
no, it never died on my while driveing around. once i get it started, it runs good. better than my other camaro. it just smokes sometimes from the exhaust, with a foul odor, with the trouble to get it started now.
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
TheExaminer
Aug 26, 2015 04:59 PM
killer777
Aug 8, 2015 02:47 PM
