msd OEM style GM external coil
Old May 17, 2001 | 11:08 PM
speedlvr's Avatar
If you have got one of these, were you able to tell a big difference?
Old May 18, 2001 | 12:27 AM
Guest
Guest
Posts: n/a
Only way a coil will make a difference is if you are having problems igniting the mixture. On a somewhat stock car, its not going to make any difference.
Old May 18, 2001 | 04:04 AM
ronterry's Avatar
Car: '94 Corvette
What about being able to open up the spark gap, for a better (not a good word) hmmm, more efficient burn.
I do run the MSD HEI coil, BUT in line with an MSD 6AL @ 6500RPM’s.
I once dropped an Accel super coil, on my '81 with some 'hype' plugs (rapid fires), and it ran like crap -pop-pop-his-his. I guess it found a weakness in one of my plug wires(Accel 8.8) ???
I guess what I'm saying there is that they can cause some adverse effects also.
Ron
'82 Trans Am
'81 Camaro Z-28
'94 Vette LT1 Coupe
Old May 18, 2001 | 08:13 AM
speedlvr's Avatar
About the only stock thing left is the interior. I went from 305 to 383. I should probably get an MSD 6AL box or comparable to boost the ignition to match the engine size change, huh? Something more than just an aftermarket coil?
Old May 18, 2001 | 03:20 PM
Guest
Guest
Posts: n/a
That would be a good idea. It will do much more than a coil ever could.
Old May 18, 2001 | 03:25 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
With "just" an aftermarket spark coil, I noticed a little extra push in higher rpm's. You could always put the MSD coil on now, and get the box later.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old May 18, 2001 | 10:40 PM
speedlvr's Avatar
Thanks guys.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
