Oil pan question
Oil pan question
I'm putting a 383 in my 87 iroc, the block is from a 78 pick up and mu question is what would you recommend for a oil pan that will clear the longer stroke crank an still fit in the car with a hedman Y-pipe and headers?
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Stock sbc pans are all the same. Wether it be a 283, to a 400, they all share the same dimentions. The only difference is in the years. Some have baffles, some don't.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
