A Really odd sound....
Old Jun 3, 2001 | 03:23 AM
TorchTA's Avatar
Is coming from the tail-end of my 86.
Sounds like the beginning of an old siren or something. Could something in the rear-end be going?
It's noticeable from 40 on up to 70-80 (dont usually go faster than that)...but only when I'm actually using the accelerator.. I let off, and the whining stops...
Any ideas?
-JT
Old Jun 3, 2001 | 08:25 PM
TorchTA's Avatar
ttt.
it's still making that same whining noise.
Old Jun 3, 2001 | 10:23 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
It sounds like what I have heard about rear end gears going, or possible drive shaft outta balance. That's all I can tell ya without hearing it myself.
Old Jun 3, 2001 | 11:31 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Sounds like a pinion bearing.
They only make noise when you are on the throttle.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Old Jun 4, 2001 | 01:16 AM
EvilCartman's Avatar
Car: '82 Z28
Mine makes noise when you let off the throttle :/ planning on switching the rear to one that has disc brakes and posi within the month
Old Jun 4, 2001 | 11:36 PM
11sec84TA's Avatar
yeah,,,i had a pinion bearing go bad and it sounded just like that
Old Jun 6, 2001 | 08:04 PM
TorchTA's Avatar
Next Question:
WTF is a pinion bearing?
Seriously...its kept up fairly non-stop for about a month or so now...and I dont think the highway jaunt at 110 earlier did it any good.
What kinda damage can this do/or is it doing?
-JT
Old Jun 7, 2001 | 09:07 PM
TorchTA's Avatar
ttt
Old Jun 8, 2001 | 03:18 AM
TorchTA's Avatar
ttt again.
Now the bastard doesn't seem to have park either.
The *click* that used to be there when going from park to reverse, or reverse to park isnt there anymore.
And 75% of the time, the car wants to keep rolling when it's supposedly in park.
WTF?!?!?!
-JT
Old Jun 9, 2001 | 10:38 AM
Stuart Moss's Avatar
Since the car will not lock the transmission in "park", I would suspect that you have a transmission problem. That problem could also be associated with the whining noise you mentioned earlier although I have only heard that noise with manual transmissions because of the gears meshing - some can be quite loud. The rear end, as pointed out above, would sound more logical to me in that regard. How does the transmission fluid look and smell?
The reason you lost the locking function in "park" may be something as simple as a poorly adjusted shifting linkeage, but since you also have the whining sound, I doubt that its that simple.
Whatever it is, it sounds like it'll be expensive.
Old Jun 9, 2001 | 11:17 AM
Vader's Avatar
Torch,
You may be looking at one of these soon:
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jun 9, 2001 | 11:25 AM
Vader's Avatar
...and maybe one of these:
Later,
Vader
Old Jun 9, 2001 | 05:47 PM
Jason M 91Z's Avatar
Vader, I believe illustration A is incorrect. His car, being an 86, would have 26 spline axles...
Seriously brotha, stay away from the comp. for a little while! I think all that anti-sieze on your pancakes is making you crazy.
-Jason M. 1991 Camaro Z28
Mark_ZZ3
May 24, 2018 01:02 PM
Stryker412
Sep 20, 2015 06:59 PM
Fronzizzle
Sep 8, 2015 12:10 PM
Warlocksirix
Sep 3, 2015 12:26 PM
BlackphantomZ28
Aug 31, 2015 11:19 AM
