failed CA. IM240 smog test real bad
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
it came out as a gross polluter, here are the numbers, this is a 90 vette 350 with LO-3 heads and electronics that passed when it was in the donor 89 camaro quite easily.
`HC PPM
15mph max 126 measured 477
25mph max 101 measured 744
CO%
15mph max .79 measured .46
25mph max .59 measured .68
NOppm
15mph max 1097 measured 2327
25mph max 927 measured 1898
car stubles a little, and I know for fact the cat is hollow and its air injection pipe is off .... I personally think with a new cat and good tune up and a o2 sensor and tps adjusted I should be able to squezze by the HC problem.
the CO% and NOppm is what baffles me, the engine passed smog when it was in the donor camaro which was less than 6 months ago so I think we can rule out internal problems.
timing is right on but that all that was done prior to the smog test & the electronics are functioning correctly, so how about some help guys, but lets stay away from pouring alchohol in my tank, I can afford to pay for the parts needed to fix it right so what will be problem areas that need addressing on this engine
`HC PPM
CO%
NOppm
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
with no cat on it, your CO numbers look lean, which will cause your HC & NOx to be high. a cat alone probably won't clean up your HC enough to pass, i would get the injectors flushed with the tune-up, the new O2 sensor & new cat with the air injection hooked back up.
on the NOx part, check the EGR system, on a good running stock motor with everything working properly the NOx is normally fine without a cat, if it is out of specs, normally its not out by much.
engine temp also can drive up NOX, make sure your not overheating, a 180 T-stat & fans sets to come on around 190-200 would be good, too cold can drive up CO & HC.
