Engine Misfires Above 45-4800 RPM.
Old Jun 19, 2001 | 10:14 PM
BOWTIROC's Avatar
From: Coulterville, IL...Currently on Beale AFB, CA
Hey guys I have the HEI with a "hi-po" module, cap, rotor and an accel super coil. It has been running fine, but the other night when leaving the local street races, it started misfiring above 4500rpm or so. It runs fine otherwise though. I am thinking that maybe the coil is going bad (dropping voltage at a higher RPM) or maybe the Module (God knows those things are unpredictable). Any Ideas?
Black 89 IROC...355, Solid Crower Cam, TFS heads. 12.0 @ 120.3mph with a 1.9 60ft...all motor
Old Jun 19, 2001 | 10:46 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
If you are using the stock distributor system with high performance cap/coil/rotor combo your distributor pickup coil may have given up. They are covered with thin paper that goes brittle and is an easily overlooked component when troubleshooting.
If I misread your post.......then......nevermind.
Old Jun 19, 2001 | 11:17 PM
BOWTIROC's Avatar
I replaced the Magnetic pickup about 6 mos ago. Hopefully it is still fine.
Old Jun 19, 2001 | 11:54 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Valve springs?
ICON Motorsports
Old Jun 19, 2001 | 11:57 PM
BOWTIROC's Avatar
GOD I HOPE NOT...it is possible, how do I check for broken ones? Wouldn't it start coming on earlier (the missing)?
theshackle
Sep 17, 2020 08:26 AM
mdtoren
Aug 23, 2015 12:52 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
