What the H@LL did I unplug!! Under dash 6 wire harness...
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
I just finished removing the carpet from the ROC just to clean and stuff - and noticed I REALLY need a new floor behind the drivers seat...oh well. Anyway when I reassembled the console area, I must have accidentally unplugged a black six-wire harness that has ALDL letters on it (A B C etc) and I can't figure out what it plugs into. Wires are: two thick - purple and green/white
four thin - orange/black, black/white, blue, and light green. Any help is very much appreciated! Thanks.
"Life is pain! Anyone who says differently is selling something."
These go into your shifter....Plug the harness back into your shifter and it should be ok. These are your Neutral Saftey/Back-up light wires. If you don't plug it back in, you won't be able to start your car. It should go right into the front of the shifter.
Ask for any more help from me if you need it.
-ws6formula-
1989 Pontiac Formula WS6
69,000 miles.
305 TBI, 4.10 gears, SLP Zexel/Torsen Limited Slip Differential, 700r4 B&M TransPak, LT4 Hot Cam/Valvesprings, GM Aluminum Driveshaft, 2700 RPM Stall, Edelbrock Performer RPM intake manifold, Turbocity TB. Ran on 6-19-2001 again: UPDATED: 14.1 @ 97.68 mph. Dyno'd Bone Stock @ 172.6 rwhp, 266 ft-lbs. of rw-torque.
-ws6formula-
69,000 miles.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
