How do I know if Computer is bad??
Old Jun 24, 2001 | 01:05 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
I have the SES light to stay on all the time and I have tried the ALDL wire to read the codes and I get nothing but the light staying on. I also have the car quit idling like its in limp home mode however it just fixed started idling on its own.......also have timing jumping to 12* BTDC at idle...
Wow I need help
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
www.geocities.com/feltsb
Old Jun 24, 2001 | 02:23 PM
Vader's Avatar
BF,
Disconnect power to the ECM, either by removing the ECM power fuse or disconnecting the battery. Waint ten minutes and reconnect. Test the ECM for codes before you crank the engine.
Waiting for results...
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jun 24, 2001 | 05:42 PM
Well Vader it will still not thow a code. I will still not Idle (unless I crank the idle screw out) and at Idle I am getting 12* advance on the timing with the base correctly set at 6* ( set the base with the wire pulled it just jumps up itself on the computer)
Brian
1989 Camaro RS
F.I. 57 Belair
Aug 23, 2021 01:09 AM
92firebirdguy
Sep 1, 2016 07:53 AM
Johnoooooo
Sep 22, 2015 08:55 AM
89-91fun
South West Region
Sep 12, 2015 03:06 PM
Stryker412
Sep 7, 2015 09:11 AM
