Where do I wire my external fuel pump?
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I just installed my TPI on my LG4 motor.
Today we hooked up the external fuel pump but I need to know where to run the power wire.
Also, there are 2 fuse locations in the fuse panel for the injector fuses but since my car was originally carbed what do I have to do to get power for the injectors? Thanks
High Speed Run: 157mph
Best 1/4 mile run: 14.94@91.67mph
WS6 Trans Am.
View My Ride @ thirdgen.org
WS6 Trans Am.
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
We've been through this before at www.sethirdgen.org , here's the print again if you want it like factory. I made this sketch when I swapped my LG4 to TPI because I wanted it like the factory, no rigging.
http://members.home.net/millicanga/files/TpiWiring.jpg
Feel free to e-mail me direct if you have any questions.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
86 Camaro Sport
My Camaro Project
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
