engine pull
Old Feb 11, 2005 | 03:46 AM
scubas_90rs's Avatar
Car: 90 RS, 83 z28, 85 ranger
Engine: none, 350, 2.8
Transmission: none, t-5, 5-speed
engine pull
i am going to be pulling the engine out of my rs soon and be puttin it in my z28. i was wondering if it would be easier to pull the engine with the trans or with out. or pull the trans but leave the bell housing. i have never pulled an engine with the trans before. also would installation be easier eaither of the 3 ways? i am lazy and don't want to much work if i don't need to have to much. thanks in advance
Old Feb 11, 2005 | 06:24 AM
ede's Avatar
ede
i think with out is easier, but it's not a big deal either way
Old Feb 11, 2005 | 11:34 AM
88firebird's Avatar
Car: 89 GTA (88 Firebird V6 to V8 conversion RIP)
Transmission: 5 spd
I pulled the 305 out of a parts car with the auto tranny and it wasn't too difficult... I think it may be easier just because you don't have to wrestle with the tranny under the car. Only problem you may have (happened to me) is lifting the engine and tranny high enough to get it out of the car. The hoist I was using couldn't lift high enough, so I had to get a buddy to lift up the tranny to get it out of the car.
Old Feb 11, 2005 | 12:41 PM
well right now i don't have a hoist don't know anyone that has one so my next option to use is a tractor with a loader on it. it will be able to lift high enough. but i will try to find a hoist in the time i am getting the rest of the money for the swap. thanks for the info.
Old Feb 11, 2005 | 01:37 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
IMO its quicker to just disconnect the trans. Sure you could pull the trans as well but you need to disconnect the tq arm, cooler lines, X member it just makes a big mess and the hood must come off this way. Seems like more work to me and I hate work.
Old Feb 12, 2005 | 05:06 PM
well i don't have to worry about trans lines or a hood anyway. the hood has to go onto the other car anyway so it will have to come off.
Old Feb 14, 2005 | 10:17 AM
88firebird's Avatar
Transmission: 5 spd
One thing I will warn you about, is if you pull the engine and tranny at the same time, you will have a huge mess of tranny fluid under the car... in my case I wanted to take the entire drivetrain out anyways, so the extra work of taking out the crossmember, driveshaft and torque arm had to be done anyways....
Old Feb 14, 2005 | 12:44 PM
yeah i have to do a complet drivetrain swap also. i am not worryied about a mess. that is what floor dry is made for.
Old Feb 14, 2005 | 05:14 PM
88firebird's Avatar
Transmission: 5 spd
LOL make sure you have plenty of it tho! ha ha
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
