What should I set my timing at???
Old Jun 28, 2001 | 01:27 PM
CamaroX84's Avatar
I believe I currently have my timing set at 8 degrees BTDC. I run premium fuel only. Should I leave it there or can i give it a couple more degrees? What do you guys have your timing at? All mods are listed in sig. Thanks in advance.
1984 Camaro Sport Coupe - 73K Miles, Rebuilt 355 TPI L98, Crane 2032 CompuCam - 214/220 @ .050", Crane adjustable fuel pressure regulator, MSD Blaster coil, custom burned PROM, stock TPI intake, Accel 24# injectors, gutted air box with K&N filters
F41 Suspension Package, 700R4 Tranny, TCI Breakaway torque converter, 3.27 Disc Brake Posi Rear
Hooker Shorty Headers, Catco High-Flow 3" Cat, Flowmaster 3" American Thunder Cat-Back
New Paint
Best 1/4 Mile Run (with old LG4 motor):
16.760 @ 80.74 MPH
Coming Soon:
Aluminum Drive Shaft
Old Jun 28, 2001 | 01:34 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Whatever the custom PROM wants. It SHOULD have already had the spark advance optimized. Most eprom writers generally set the "Base timing" to the stock setting necessary for the car. In the case of TPI, 6* BTDC for TPI.
Altering the base timing of the distributor (especially on an optimized eprom) may induce knock incidences. It's amazing how much knock retard is pulled from a TPI @ WOT...seems to be a common observation when a person first hooks up their car to a scan tool and boot it. Many guys consider these knocks incidences to be false as they are inaudible. Others believe the knock is actually occuring at the early stages and the ecm is just being too agressive in its retard.
Regardless, when the ecm sees these "knock incidences" (real or false), the ecm generally pulls out more spark advance than the the little extra you gave it. Kind of like taking 1 step forward and 3 backwards.
If you REALLY believe you need that extra 2*, then get your eprom re-done.
[This message has been edited by Glenn91L98GTA (edited June 28, 2001).]
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
