400 sb?
Old Feb 16, 2005 | 06:06 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
400 sb?
did they ever make a 400 small block with a 1- piece seal? looking for emmission reasons.
Old Feb 16, 2005 | 06:15 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
GM certainly didn't. Don't think any of the aftermarket blocks are 1 piece RMS either.
Old Feb 16, 2005 | 10:02 PM
BowtieDriver2's Avatar
Car: '01 sonoma & '91 camaro
There are adapters made that convert a 2 pc seal to a 1 pc and a 1 pc to a 2 pc. I dont remember who it is that makes these but I know they are being produced. dont know if that helps?
Old Feb 17, 2005 | 12:09 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There are adapters to put a 2 piece RMS crank into a 1 piece RMS block, but not the other way around. It sounds like he needs a later block to pass off as an original engine to pass a visual inspection.
Old Feb 17, 2005 | 04:58 AM
ede's Avatar
ede
i don't think an inspector would ever know, or see the seal.
Old Feb 17, 2005 | 09:48 AM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
If its getting inspected i belive the only way to tell if its not a 305/350 is the casting number, and the balancer(has some extra holes in it for the external balance). I dont think any inspecter is going to notice either, plus both could befixed or covered up, a cover on the balancer, or some home made crud for the casting number.
Old Feb 20, 2005 | 01:05 AM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
well the problem is i am looking at a motown lite block,but i dont think would be even be able to tell do u ? why does it matter if it is 2piece verse 1 piece? do u just tell the inspector it is a 305 and it can still pass smog?
Old Feb 20, 2005 | 02:46 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
305's 350's and 400's are all small block chevys, so they all look exactly the same (within reason) its the bore diamter and such thats different, theres no way short of running casting numbers that an inspector could tell
Old Feb 20, 2005 | 05:03 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
some inspector who really knows SBC's might notice the diffrent # of freeze plugs but that and the balencer are the only external diffrances
Old Feb 20, 2005 | 12:42 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
thanks for help, i think i will be fine then.
Hotrodboba400
Dec 10, 2019 07:07 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
