purpose of 6.0 rods?
Car: 1988 Camaro SC
Engine: 383 Stroker
Transmission: TH-350
you can use the 6.0 rod if your stroking the motor to a 383 with using the stock 350 crank. if you go with the 5.7 inch rods you have to buy 400 crank.
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
With 6.0" rids it makes the angle that the rod is at shorter, making it 'push' the piston into the wall less.
The ONLY way to stroke your motor is with a different crank, changing the rods will not change your CID, if you try to use a 6.0 rod with a piston intended for 5.7" rods your going to run into trouble, BIG trouble.
what can be gained? Longevity.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Car: 92 Camaro RS
Engine: 305 TBI
Originally posted by Apeiron
How could the stroke on a 350 possibly change with a stock 350 crank?
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
longer rods also increases the "dwell" at the top of the cylender allowing pressure to build better, and therefore increasing power, you want the longest rod possable for the biges't bang for your buck
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
RacerDonnie13, Bartbyu
Please dont give of some bull**** info that people are go and repeat making them sound like a dumbass also. If you dont know specs for sure dont repeat them.
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
