Good deal or keep looking???
Old Mar 15, 2005 | 12:43 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
NEW 550+ HP Dyno Tuned Big Block Pump Gas Crate Engine
Block Baked, Maged, Sonic checked
Bored
Deck Milled
Competition Hone
Line Honed
Oil modifications
De-burred
Race style Coated Bearings
Balanced
Oil Galley Plugs custom
Main Seals
ARP Rod Bolts
ARP Main Studs
ARP Head Studs
ARP Timing Cover Bolts
ARP Intake Manifold Bolts & Washers
ARP Flex Plate Bolts
Forged Pistons
File fit Molly Rings
SFI Balancer
SFI Flex Plate
5/8 oil pick-up
Stock Oil Pan
Bulldog Cylinder Heads W-ERE custom Valve Job & Port Configuration
Custom Hydraulic Cam
Hydraulic Lifters
Billet Double roller Timing Chain
Reconditioned Timing Cover
Blueprinted Oil Pump assembly
T/A Sp1 Intake
Intake Manifold Oil Shield
T/A Double Grooved HP coated Cam Bearings
Brass Freeze Plugs
HP Gaskets
Custom 5/16 HD Push Rods
Assembled
Blueprinted
Dyno Tuned
Only $6799.95
Add a Custom Build Pro Race Converter and Street Strip TH400 Transmission for just $1200.00.
Old Mar 15, 2005 | 01:34 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
One would think if the engine was "dyno tuned" they would have a more accurate description of the numbers then 550+ hp.
Old Mar 15, 2005 | 01:38 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
They promise 550+ HP . You get constant dyno update as it tested and tuned. But you will get atleast 550+
Old Mar 19, 2005 | 06:07 AM
SOLID LIFTER's Avatar
Car: '87 Mustang LX
Engine: 5.0
Sounds like a good deal for an assembled aluminum headed BBB. What rocker arms does it come with, stock type or aftermarket?
hectre13
Dec 11, 2023 08:14 AM
InfinityShade
Aug 22, 2015 08:00 PM
Hello, Michael
Aug 20, 2015 03:19 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
ChevyZ71
Aug 13, 2015 07:30 AM
