code 33 and code 44
code 33 and code 44
ok got my code scanner and got a code 33 and then a 44. today we unplugged the maf and the car ran fine when we reconnected it with the car on it stalled i started it back up again and .it started with rough idle down to 500 then up 1000 then back down and it smells like it is running rich ...now what do u guys think it is before i go out and 150.00 on a new senor....any help would be good
Check your connector to the maf. If the sockets(5) are expanded change it. Swap your maf and burnoff relays and see if you get another code. Be sure and clear the ecm when you do this. If you get code 36 your burnoff relay is bad. Replace it. First place to look is your connector though.
Car: 86 T/A
Engine: 5.0 TPI
Code 44 ... Lean Exhaust... caused by most likely a vacuum leak.
Check all plastic vacuum lines for connection and that they aren't cracked.
Change O2 sensor and check wire to make sure it's not melted to the exhaust.
Fuel Filter.
Make sure intake manifold bolts are tightened to torque specs. Especially the middle 4.
Check connections after the MAF for air leaks. MAF to Air box to Bellows to TB.
Make sure plastic air box is not cracked. They are bad about cracking right on the seam which is hard to detect.
Long shots:
Plugged Cat or Muffler
Air Diverter Valve malfunction.
Cold start valve leaking air (o-rings)
Injectors leaking air (o-rings)
Bad ECM (unlikely)
Bad PROM (unlikely)
Fuel Filter.
Long shots:
Bad ECM (unlikely)
Bad PROM (unlikely)
I had the same problem... it was the O2 sensor.. i did a complete diagnosis on the MAF and found nothing... I then realized that my O2 sensor could wiggle around.. replaced it with a bosch o2 sensor and my codes are gone and i am getting about 5 more mpg... whoo hoo
Mike
88 Iroc-Z 350 tpi, Hedmann Headers, 3" Cat Back, MSD Ignition, K&N, AirFoil
Mike
Car: 89 IrocZ
Engine: L98-ish
I had the same thing, except no code 33...SE light kept coming on, code 44 was set.
I monitored the O2 voltage and it would dive down to 10-15mv. Did the diag in the Helms, which states "unplug MAF and see if O2 voltage returns to normal" or similar, it did, idle smoothed out.
I was able to borrow a known good MAF to test it out with, and all was well.
$254.00 later for a new Bosch MAF, been fine ever since.
