engine seal
Old Mar 20, 2005 | 04:56 PM
fearfactory17's Avatar
Car: 1989 Pontiac Firebird
Engine: 2.8L V6
Transmission: auto
engine seal
does it really work? the stuff that you put in your radiator after you flush it, to seal head gaskets, i used one bottle, and the smoke stopped a little bit, should i add another bottle?
Old Mar 20, 2005 | 07:19 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Re: engine seal
Band-aid.
If there is a problem its been my experience that there is not a liquid in the world that will fix it.
What are the symptoms that led you to use this in the first place?
Old Mar 21, 2005 | 11:22 AM
Engine: 2.8L V6
Transmission: auto
blowh head gasket, my car shouts out alot of white smoke, and water drips from the tailpipes, i figured giving that engine seal a try might help, but guess not, i guess im going to have to replace the head gaskets
Old Mar 21, 2005 | 12:04 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
i wouldnt use that as it can actually end up cloging the cooling system.
get a nice set of Fel-Pro PermaSeal head gaskets.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
formula_novice
Aug 18, 2015 08:48 PM
86White_T/A305
Aug 17, 2015 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
