Hard to start when hot
Old Mar 26, 2005 | 12:50 PM
magadith's Avatar
Car: 83 Trans-Am (Recarro)
Engine: 305 4bbl
Transmission: 5 speed manual
I have 83 firebird 305, carb
Here is a problem I can't figure out that been going on for about a week. When the car is warm, its hard to start! The engine is hard to turn over. It aint the starter. I had it tested, passed with flying colors, cleaned and tightend the connections. Other in my Haynes manual says carb. Checked it out and its fine. And the battery is fully charged, so thats ruled out. I did change my distributer from a junkyark. I had a vacume advance when I shouldn't had one, so I got the right one. I got a code 42 from the computer (ignition circut). I canged the Ignition Modual (3 diffrent ones from the junkyard and all worked .WTF!!!
Old Mar 27, 2005 | 07:51 AM
magadith's Avatar
Engine: 305 4bbl
Another BB told me that it could be the alternator. Is that possable?
Old Mar 27, 2005 | 09:24 AM
Vader's Avatar
"Hard to start?" Throw us a little more info. Is it an issue with protracted cranking, or is the starter unable to crank the engine when it is hot?
Old Mar 27, 2005 | 05:15 PM
sellmanb's Avatar
Car: '86 Berlinetta
Hard starts when hot are commonly (but not always as Vader was trying to get at I'm sure) the starter being too close to the exhaust pipes and becoming more resistant to any electricity, thus slowing the starter down increasingly.
The starter can test good, but it's when the starter is being "heat soaked" (as it's commonly called) that it when the voltage doesnt get through.
The cure : re-route exhaust to farther from the starter
or the more common one
get an LT1 starter, or any other mini-starter.
I'm still curious what your symptoms are though before you go out and just buy a mini starter lol.
Old Mar 27, 2005 | 09:41 PM
magadith's Avatar
Engine: 305 4bbl
My symptoms are its hard to turn the engine over when the engine is warm, like if the battery is low, but the batt. is fine. I would like to re-route the manifold, but I don't think I can do that in a day. I'm going to try to use a heat shield for the starter.
Old Mar 27, 2005 | 11:11 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
Check your timing, if its off it will be hard starting.
Old Mar 28, 2005 | 08:05 AM
magadith's Avatar
Engine: 305 4bbl
timing is fine
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
86Base
Aug 8, 2015 01:34 PM
