adjusting rocker???
Car: '86 Trans Am
Engine: stout 350
Transmission: automatic
adjusting rocker???
Ok, my friend says after i break in my new 350 I'll have to go back in and adjust the rockers or something like that. Is that true, or is the initial lashing enough???
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
you'd want to re-adjust valve lash after a bit, especially with a flat tappet cam. just do it whenever it starts making noise. there is no rule of thumb.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Originally posted by blacksheep-1
I've never had to re-adjust the lash on a hydraulic cam.
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Your running a hydraulic in a racemotor? why not step up?
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
naaaah... you can't hear them over the gear drive anyway
-- Joe
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Depends on what cam you have and how you adjusted the valves. If you have a hyd. cam you will not have to re-adjust the pre-load IF you did it correctly. If it's a solid cam, you will most likely have to re-adjust after break-in. I always re-adjust mine (hyd.) after initial break-in with the motor up to temp and while it's running just so I know it's right.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
And also do it while running.
-- Joe
Car: '86 Trans Am
Engine: stout 350
adjusting
How do you adjust the valve lash after you do it, the book im using has the before install valve lash adjustments, but doesnt go over what you have to do to adjust them afterwords. So direction would be great.
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
As exhaust just starts to open, adjust the intake, as the intake just starts to close adjust the exhaust. per cylinder, take the play out of the pushrod and then go 1/2 to 3/4 turn more. That's why I don' tunderstand why you would readjust hydraulic lifters, there's play there that is taken up by the lifter unlike a flat tappet that has a measurement value, such as .027 and .030.
