ported l-98s or trick flow, and whats my comp?
Old Mar 31, 2005 | 09:52 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
ok my motor now is 9.65:1, what would my compression be with some l-98s"ported" and what would i be at with some trick flows, also what heads would be better for my motor? 212-218 264-270 487-495 110, 1.52 roller rockers, ported highflow tpi setup,hypert flat top pistons, nx nitrous kit 35-150shots, what shot should i run? can anyone help me with these qs thanks also would there be a difference in tuning them, if so what would be easer to tune, im goin to get into buring
Old Mar 31, 2005 | 10:14 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Can't answer your question...I think I made a reply to some of this on the GP Board...
If you do not know you current heads combustion chamber volume, you cannot know what it will be with any other head...unless you pull yours (and check the other things I spoke about on the GP Board).
If I were you I'd be leary about the 9.65 number...IIRC you bought a supposed rebuilt motor and it ate itself at 400 miles? Not sure I'd belive the CR to be correct, or anything else the seller told me.
If I have you confused with someone else, my apologies.
Old Apr 1, 2005 | 09:08 AM
Car: 92 1500p\u 2wd
no your right....well the stocl heads arnt they like 67cc or somthin like that? so i guess im stuff, i cant buy heads unless i rip into the motor to check on all the parts and to get the info to findout the comp? or what am i supost to do, i guess what i need to know is IF i got some ported l-98 heads and there 58cc and IF my moter is runnin 9.65:1 then what should i be at comp wise with some l-98s? i dont want to have to high of comp but i want better perfoemance and the next step is gettin heads.......
Old Apr 2, 2005 | 11:05 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Assuming you have 083's (stock L98 heads) the chambers should be 64cc's, they're probably still close to that even after a rebuild.
Since the motor needs work, why not pull a head and find out what you have...i/e pistons and chambers...check to see how far down the piston is from the deck (at TDC), then plug in all the numbers into a CR calculator to see what you'll come up with.
If I didn't know for sure what I had, I wouldn't take a chance on spending a $1000.00+ on heads, only to find out that they weren't what I really wanted to have.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
69GTOby
Apr 18, 2016 02:34 PM
84redta
Sep 19, 2015 09:58 AM
toronto formula
Sep 10, 2015 07:31 AM
hdis2002
Sep 8, 2015 02:52 PM
