Found out what happened to my first motor...
Old Apr 7, 2005 | 02:07 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Rod bearing spun
Spun bearing vs good bearing
Attached Thumbnails Found out what happened to my first motor...-bearing-1.jpg
Old Apr 7, 2005 | 02:08 AM
pasky's Avatar
Crank journal:
Attached Thumbnails Found out what happened to my first motor...-crank-journal.jpg
Old Apr 7, 2005 | 02:09 AM
pasky's Avatar
Both spun bearings on the same rod.
Attached Thumbnails Found out what happened to my first motor...-bearing-3.jpg
Old Apr 7, 2005 | 02:11 AM
pasky's Avatar
Spun Vs. Good Profile view.
I found all this when disassembling my old block because its going to the machine shop tomorrow.
Attached Thumbnails Found out what happened to my first motor...-bearing-2.jpg
Old Apr 7, 2005 | 02:16 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
You know what they always say...a spun bearing is a bad bearing... OUCH!
Old Apr 7, 2005 | 03:02 AM
pasky's Avatar
Like i've been posting. I got a 383 in the works. Block gets cleaned, new cam bearings and feeze plugs tomorrow.
Come monday...
"We can rebuild him. We can make him better than before."
Forged 383 assembly sittin in my garage .
Old Apr 7, 2005 | 08:18 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Make sure they check the rod really well for excessive heat, unless you're getting new rods as well.
Old Apr 7, 2005 | 12:02 PM
pasky's Avatar
Rotating assembly is all new, only using the block.
83 Crossfire TA
Jan 3, 2016 01:26 PM
SlowAZ28
Sep 2, 2015 05:19 AM
Thaney9
Aug 29, 2015 03:16 PM
bjpotter
Aug 12, 2015 06:06 PM
antares57
Aug 6, 2015 07:47 AM
