external fuel pump
Old Jul 30, 2001 | 09:50 AM
RW91B4C's Avatar
external fuel pump
Before my 383 goes in I want to install an aftermarket enternal fuel pump, havent decided which one yet. My question is can I run a good aftermarket external pump while keeping the stock in-tank pump, and if the stock in-tank pump fails will the external be OK, will the car still run? I'm trying to avoid pulling the tank, but if I have to I will - since it would be the last time, thats the reason for going external. I know some of you guys must be running externals, so what did you do about the stock in-tank pump? Thanks for your help
91 B4C 305 TPI - SOON TO BE 383
TREMEC 5-SP, STOCK 1-BOLT REAREAND w/342 GEARS, K&N, AIRFOIL
EDELBROCK HEADERS, DUAL CAT TO HOMEMADE Y-PIPE & 3.5" SINGLE PIPE W/ FLOWMASTER, CRANK PULLEY, MSD, FUEL PRESS REG, COWL HOOD, WELD WHEELS
14.1@ 98MPH
OTHER RIDE
67 CAMARO - STREET CAR, BIG BLOCK, PUMP GAS
350TH w/ATI 10", 12-BOLT w/373 GEARS
10.94@124.13 ON MOTOR - ET-STREETs w/MUFFLERS
Old Jul 30, 2001 | 11:08 AM
ede's Avatar
ede
you can do it like you want, but if it were me i'd pull the one in the tank
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
