Lifters
Old Jul 31, 2001 | 12:48 AM
SCFORMULA1's Avatar
Lifters
I just got some new cran Hydraulic roller lifters for my new cam and was wondering why when i push the push rod in to the lifter it goes in about a 1/8 of an inch could this be why my car is runnig like crap? Thanks for any help
Scott
Its a 89 305 TPI
Old Jul 31, 2001 | 01:15 AM
SCFORMULA1's Avatar
i mean crane
Old Jul 31, 2001 | 01:08 PM
ATOMonkey's Avatar
Hydraulic lifters are spring loaded. Do you know how to adjust hydraulic lifters?
'89 Red Formula 350- 350 .060 over forged pistons 232* @ .020 cam Performer RPM Holley 750 DP Vortec 1.94 1.50 Accel Coil and dist. Hedman shorty headers Dual Exhaust w/ cutouts 1LE WS6 suspension, wheels, and brakes, 9 Bolt 3.27 Posi Edelbrock LCA's & Track bar subframe connectors 700R4 A&A snorkel scoop Eclipse Head Unit Delco Bose Speakers 2 12" Pioneer subs w/ 400 watt/chanel amp
Old Jul 31, 2001 | 04:00 PM
RW91B4C's Avatar
Since they are new they need to be soaked in oil over night, then take a pushrod and pump the lifter by depressing the plunger a few times. This will prime the lifter with some oil, but for the lifter to fully pump-up it will have to be run - hence the lifter clatter at initial start up. If you'll notice - on a lifter that has been run it is almost impossible to depress the plunger.
91 B4C 305 TPI - SOON TO BE 383
TREMEC 5-SP, STOCK 1-BOLT REAREAND w/342 GEARS, K&N, AIRFOIL
EDELBROCK HEADERS, DUAL CAT TO HOMEMADE Y-PIPE & 3.5" SINGLE PIPE W/ FLOWMASTER, CRANK PULLEY, MSD, FUEL PRESS REG, COWL HOOD, WELD WHEELS
14.1@ 98MPH
OTHER RIDE
67 CAMARO - STREET CAR, BIG BLOCK, PUMP GAS
350TH w/ATI 10", 12-BOLT w/373 GEARS
10.94@124.13 ON MOTOR - ET-STREETs w/MUFFLERS
Old Jul 31, 2001 | 07:50 PM
SCFORMULA1's Avatar
I thought if you put the lifters in oil over night that would void any warrainties that were on it? Is this true?
Old Aug 1, 2001 | 12:15 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
It shouldn't. That's all that's in the lifter when the engine's running. That's how oil gets up to the rocker arms, valve tips, springs, etc. I don't think they (the company) would ever know that you did it if you did.
AJ
Old Aug 1, 2001 | 02:22 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Actually oil is all your supposed to use on roller lifters. You could prolly use a small amount of assembly lube on the rollers/cam lobes, but don't use that thick moly cam break in stuff, thats only for flat tappets.\
tyeo098
Nov 30, 2015 06:27 PM
codeysabatini
Nov 10, 2015 04:07 PM
skinny z
Oct 5, 2015 06:23 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
dimented24x7
Sep 6, 2015 03:51 PM
