Replace EGR valve
Old Aug 2, 2001 | 12:23 AM
Raymond 5.7 89 Formula's Avatar
Replace EGR valve
I know I will have to remove plenum and runners to get it out,but will I have to remove fuel rails also? And what is the best adjustable fuel pressure regulator I think most people liked the Holley one. Thanks for any info.
Old Aug 2, 2001 | 01:02 AM
jobryan26's Avatar
To replace the EGR you don't have to remove the runners, only the Plenum and Throttle Body. The back bolt can be a little hard to get to other than that it's very easy.
Tips:
1. There is a connector for the EGR temp sensor is located by the Distributor, DO NOT cut the wire and then remove the sensor(that's what I did and I soldered it back on and burned up the sensor)
2. Remove and clean the IAC Valve and Passage Ways since you have the Throttle Body off.
3. Remove and clean the MAT sensor since you have the Plenum off.
Have any questions please feel free to e-mail me
Trans Am:
(Engine)305 TPI
180 Degree Thermostat
JET Fan Switch
TB Bypass
Accel 300+ 8.8 Racing Wires
Accel Super Coil
Bosch Platinium Plugs
Custom Ram Air with K&N
Removed Emissions Equipment & Cat.
(Stereo)Full Kenwood Excelon System
See my Ride:
https://www.thirdgen.org/rides/index...ew&rideid=1324
Member at kyfbodies.org
[This message has been edited by jobryan26 (edited August 01, 2001).]
Old Aug 2, 2001 | 01:03 AM
jobryan26's Avatar
ooops
1992rs/ss
16
Jan 28, 2016 09:58 PM
Out-Cast
Aug 17, 2015 10:57 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
