engine weight
Old Apr 13, 2005 | 12:08 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
engine weight
what is the engine weight in our cars?
Old Apr 13, 2005 | 02:30 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Depends which engine... I would guess that the iron headed TPI 305 in yours is about 645-700 lbs with all the bracketry.
Old Apr 14, 2005 | 08:18 AM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
i was thinkin more like 400/500 lbs running
Old Apr 14, 2005 | 10:41 AM
wesilva's Avatar
Transmission: 200R4
Most sources quote 560 lbs for a basic iron headed long block from intake manifold to pan. The TPI is heavier obviously than a carb. Throw in your accessories and brackets depending on your options and I'll take back my original estimate and say about 625 lbs.
The Motown All Aluminum small block built by Super Chevy is around 465 lbs.
customblackbird
Aug 15, 2021 10:16 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
E Rod
Aug 28, 2015 05:17 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
