How to identify engine
Old Apr 18, 2005 | 08:58 AM
cardork's Avatar
Okay, so I finally wound up getting my project car. It's a 1984 Z28. It's in pretty rough shape, but I didn't pay all that much for it either. I'm hoping to really make it nice, but in the meantime, I need some help. The guy that I bought it from said that the engine had been replaced but he wasn't sure whether it had been replaced with the regular carburated 305 or the high output version. Is there a way that I can tell by looking at the engine? I didn't really care which engine it had in it when I bought it as I plan on swapping it out eventually but I would like to know in case I have to buy parts for it before the swap. Any help you guys could offer would be great. I look forward to talking to everyone.
Old Apr 18, 2005 | 09:35 AM
ede's Avatar
ede
you can tell by looking at the numbers and running them at www.mortec.com
Old Apr 18, 2005 | 10:40 PM
Charman234581's Avatar
Car: '88 Camaro RS,
Engine: 305 TBI
Axle/Gears: Stock
The difference in the regular and the HO motor is the heads and the cam. Run the casting #'s on the heads and hopefully that will tell you.
But for 95% of the parts that you might need between now and the time you swap it won't matter. They will be the same.
Old Apr 18, 2005 | 11:29 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You can't tell from the casting number. You can only tell from the suffix codes.
Also the heads are the exact same either 416's or 601's. The only engine differences are the pistons, cam, and timing curve.
Old Apr 18, 2005 | 11:43 PM
sellmanb's Avatar
Car: '86 Berlinetta
The H.O. would have the dual snorkel intake, that would be a good sign right there.... but a 305 in this case.
Old Apr 19, 2005 | 09:29 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If the engine's been swapped though, that doesn't necessarily mean the HO air cleaner was added in as well.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
Street Lethal
Aug 14, 2015 08:25 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
