Burnin' up!
Old Apr 20, 2005 | 09:32 AM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
Burnin' up!
Summer is almost here and I want to get my Air Conditioning system back in working order. Last summer, I replaced the accumulator and converted the system to 134a. Then I took it to a shop and they pulled vaccum on the system for about 20 min. After that I took it home and charge the system with the 134a conversion kit(making sure to put the right amount of oil in). This worked great for about 5 days...then it went out again. The compressor is not engaging, I guess that means that I have low pressure. Any ideas what I should do/replace to get my system working for good?
Old Apr 20, 2005 | 10:21 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
First step would be to verify the pressures in the system... A set of gauges is a good investment (~$70 at a parts store).. Then if it really is low on refrigerant, I'd add some leak detector dye (UV dye), and see if you can find where it is leaking..
Old Apr 20, 2005 | 10:43 AM
85cmroz28's Avatar
Engine: L69
I've got a guage, it's only reading 3 pounds. I'm sure that's too low. Is the dye expensive or hard to do?
Old Apr 20, 2005 | 10:48 AM
thirdgen88's Avatar
Car: 1995 Corvette
No, you can buy refrigerant with the leak dye in it... Get a can of that and enough to charge the system again, then use a blacklight to find any leaks.. Hopefully its not a leak in the evaporator (if you don't see any dye anywhere in the engine compartment, look where the water drains from the evaporator and see if any dye is there.. if it is, you know what that means.. time for a new evaporator)...
Old Apr 20, 2005 | 01:43 PM
85cmroz28's Avatar
Engine: L69
Not to sound stupid, but where exactly is the evaporator???
Old Apr 20, 2005 | 01:53 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
In the big black case on the passenger side on the firewall...the one that makes changing your two rear plugs a pain in the ***.
Old Apr 20, 2005 | 02:10 PM
85cmroz28's Avatar
Engine: L69
so do i have to take the plastic thing off to see if it's leaking?
Old Apr 20, 2005 | 02:39 PM
thirdgen88's Avatar
Car: 1995 Corvette
No, you'll see dye where the water drains out of the car underneath... That will tell you that the evaporator is leaking...
grdpdr305
Nov 17, 2010 09:02 PM
rogers92camaro
Oct 4, 2009 07:53 AM
355tpipickup
Jan 23, 2006 01:33 AM
x_wolf
Carburetors
Aug 16, 2004 03:03 PM
TA 83 Daytona
May 23, 2003 08:35 AM
