Crazy Engine installation problem with the torque converter
Old Apr 27, 2005 | 08:41 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Ok well i installed my LT1 headed 305 with the transmission attached today. Then i go to bolt the torque converter to the flexplate and i can't even get the torque converter to budge. It won't move even with with some impuse motivation. When i took the engine out i took the tranny out seperately. I could move the torque converter easily by hand to get the bolts.
What the hell is going on! I'm gonna drop the tranny now and redo the bitch. What would cause this? **** and everything was going slicker than teflon. Damn!
Help please!
Old Apr 27, 2005 | 10:43 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
You mean you couldn't spin the converter in the tranny or that you couldn't turn the motor over to get to the next bolt?
Old Apr 27, 2005 | 11:10 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
I mean i couldn't move the converter independently of the motor. The motor, flexplate and torque converter all moved together. If i rotated the motor over to align a bolt the converter moved with it.
Its crazy!
Old Apr 27, 2005 | 11:14 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Do you have paint or some other matter in the alignment hole on the crankshaft?
Old Apr 27, 2005 | 11:16 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
I don't think so. I just pulled the motor, put it on the engine stand. Then i swapped cams, and heads, then bolted the tranny back up.
Old Apr 27, 2005 | 11:18 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Can you turn the torque converter in the opposite direction?
Old Apr 27, 2005 | 11:21 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Nope won't budge.
Old Apr 27, 2005 | 11:27 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Save yourself the time and aggrivation and just do it.
Old Apr 28, 2005 | 12:59 AM
EvilCartman's Avatar
Car: '82 Z28
Did you pull the converter up to the flexplate to bolt it up or... was it already against the flexplate It might not be engaged properly into the transmission and is sticking out too far.
Old Apr 28, 2005 | 01:08 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Thats probably it, the TC was already touching the flexplate. I thought i had it seated properly, because if its not the tranny will not bolt up. But i bet thats it, damn.
Tranny dropping time!
Old Apr 28, 2005 | 01:09 AM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
it coudlnt hurt to jsut loosen everything up, and move the motor away a bit. Make sure you get that converter seated properly if it isnt already.
Old Apr 28, 2005 | 01:12 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
I might try and see if i can pull the tranny away from the block offthe dowels if i can. Hopefully that will work because i don't want to take the driveshaft out. I have some extra crossmembers under there for my decoupling torque arm that might get in the way.
Old Apr 28, 2005 | 09:17 AM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
This is why I always pull and install the engine and transmission as one unit. It just seems easier to me.
Old Apr 28, 2005 | 10:54 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
I did install them together. It was wicked easy to drop everything in. It dropped in like nothing, in 30 minutes.
I see what i did. In my original post i said i installed the LT1 headed 305 with the motor. That doesn't make any sense. It should be with the transmission.
Old Apr 28, 2005 | 11:50 PM
Car: '82 Z28
Did you get the torque converter sorted out ok?
Old Apr 28, 2005 | 11:57 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
You should be able to pull the TC back and have a decent ammount of clearance with the trans installed. If not, its not keyed into the front pump correctly. I wouldnt turn it any more untill you get it sorted out.
84z96L31vortec
Aug 20, 2017 12:16 AM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
gwade12
Aug 8, 2015 08:17 AM
