Rod Choice?GM PM v Scat I beams.
Old May 5, 2005 | 07:49 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Using a L31 Vortec short block as the basis of my 383 build up.
Given that the Vortec PM rods are apparently the same ones as used in the LTX / ZZ4 engine(GM rated to 450Hp ) ;
would you use these or buy Scat forged 4130 I beams ones?
Trying not to spend money on parts I don't have to have.
Old May 5, 2005 | 09:52 AM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
What kind of power do you plan to make? And at what rpm? NA?
Old May 5, 2005 | 02:31 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Go with Scat I-beams with capscrews. They will much better for clearance.
Old May 6, 2005 | 07:27 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Am building a street / mostly strip 383 broadly based around the proven modified versionsof the Fastburn /ZZ4 crate engines.
Have accumulated same or better parts
Have 4 bolt Vortec block , 113 and TFS 195 heads , ZZ4 and ZZ9 cams , LT4 springs ,Magnum rockers,Vic Jnr converted to EFI.
Looking to build strong consistant engine , prob undercammed with the cams I have but potential to add more cam.
Salle Chevrolet have a engine that makes 464Hp @ 6100 / 440FTlb . (Max rpm 6500 )
Uses stock ZZ4 short block with the PM rods. AFR 195s ,
Vic Jnr ,"846" cam and 1.5 rockers,750 carb.
Only 10.1:1 CR.
If I can get 400+ reliably I will be happy.
Old May 7, 2005 | 11:16 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
i went with the scat 7/16" capscrew I beam 6" rods for my build.got an awesome price on ebay from racers outlet or dirt track thunder.can't remember which.under 230 bucks shipped.
went with them for clearance and strength reasons.VERY nice rods!
Eric
Ed1LE
Sep 30, 2018 09:14 AM
gixxer92
May 18, 2017 11:20 AM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
