valve train tick
Old May 5, 2005 | 05:49 PM
eddie89TA's Avatar
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
valve train tick
ever since i installed my 1.6 rockers i seem to have a tick in the valve train. somewhere in the 5,or 7 cylinders but the tick seems to be coming from the lifter valley not at the rocker. i first set the lash at 1/4 past zero lash then i went to 1/2 past zero lash no change, the tick goes away when i increase the rpm from idle 700 to about 1500. i run 5w30 mobile one oil. i also added new lifters also. about a month prior to the new rockers. it taps like hell when oil temp goes up. what ya think? thicker oil... like 5w40 do i have to much lift ?
Old May 5, 2005 | 07:24 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
to locate which rocker or lifter is causing the tick take the push rods out one at a time till it stops ,that is to say only one push rod out at a time --- it could be valve spring bind if you have a high lift cam or as simple as a rocker stud pulling out ... hope you find it ...good luck tao
Old May 6, 2005 | 03:55 PM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
according to the edelbrock literature the springs should be good till .560 lift. i am at .525 at intake with the 1.6 rockers ???
Old May 6, 2005 | 07:31 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
Axle/Gears: ford 9in 4:56 to 1
did you change pushrods also?
could be a bent one
Old May 7, 2005 | 06:53 AM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
i rolled them across a piece of glass and they all rolled straight. why when i throttle slightly does it shut up??
Old May 7, 2005 | 07:27 AM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
well i went out today 1st thing. with a long vacume hose to my ear.. i listened to the motor, when i put it in drive the motor quiets down a bit, oil was cold, (thick). it started tapping ,after it settled in warm idle, i put it in drive and chocked the wheels and it shut up under load man... i am ready to put my stock rockers back on! is the cam in my profile enough lift? if so hmm. back on they go.. i am at 1/2 past zero lash. should i try 3/4 or 1 past before i give up? will all that preload hurt the motor?
Old May 7, 2005 | 01:29 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
are you running solid lifters or hydrolic ? i didnt see it on your first post ... if they arnt solid perhaps one isnt pumping up ... personaly i dont care for multi wieght oils and use 30w or somtimes even 50w if its hot out and im running hard ... somthing else ...do you have a high volume oil pump?is the pressure low at idle? these could be the reason too ... good luck tao
Old May 7, 2005 | 09:05 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
1/4 past zero lash shouldnt tick.a full turn will cause a severe bog in some cases.are you positive it isn't an exhaust leak?try straight 30 wt.as stated above,also do you have screw in rocker studs?with that lift you definately should!
hope this helps
Eric
Old May 8, 2005 | 10:50 AM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
i am now positive it is pump up issue. after a 1/2 hour drive on the highway it was dead quiet. i am contemplating switching from 5w30 mobile 1 to 5w 40 mobile 1 thankf for the help..
Old May 8, 2005 | 11:47 AM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
edelbrock 6085 heads ...... yep screw in studs... hydrolic roller lifters by the way
Old May 8, 2005 | 12:00 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
ahh ... you do have hydraulic lifters ... when i adjust mine from a completly loose position i twist the push rod back and forth as i tighten the rocker nut once i feel resistance in the push rod i give
the nut one more full turn ... that should put you close to the center of travel in the lifter ... let us know what your solution is ... best of luck to ya ... tao
david068513
LSX and LTX Parts
Nov 15, 2015 11:37 PM
corey8084
Sep 17, 2015 02:56 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
Stryker412
Sep 7, 2015 09:11 AM
