Getting there...
Old May 15, 2005 | 11:08 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
Getting there...
I set out to build this block 7 years and 3 cars ago. Time to put those parts to use!!! Here is what it looks like so far
Old May 15, 2005 | 11:11 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
here is the new one, I have sunk $2K in the motor and trans so far.
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
pretty, but I got some paint on the engine stand, oh well
Old May 15, 2005 | 11:13 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
I used a bead blaster on the intake, I imagine this is what it looked like new
Old May 15, 2005 | 11:14 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
the tranny is getting the works too
Old May 15, 2005 | 11:18 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
I did a master rebuild kit, new drum, and bought a new "super pump" instead of trying to build up the old one. I finished the shift kit and got a Vette 2050 stall converter. It should work out real nice. I hope to get my heads back tuesday, I am having bigger intake valves put in.
Old May 16, 2005 | 12:24 AM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Well, I'm glad I caught this thread before the mods have a field day.
Looks nice. I can also say that color of that car the engine is sitting next to looks mighty fine too.
Old May 16, 2005 | 12:27 AM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
who makes that light blue engine paint?
Old May 16, 2005 | 09:22 AM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
good old gm blue 500F hi temp paint from advanced auto, I forget the brand name, I will have to look at the can. It is supposed to be the same color as the early 80s blocks in 3rdgens. Oh yeah, I do have a question....
The flexplate for my 84 305 is smaller than one for a 84 305 chevy van, and the starter is a little different. The both were lg4 blocks and had a 700r4 transmission. Whats the deal?
I had a new 305 van flexplate leftover that I was planning on using.
Old May 16, 2005 | 01:11 PM
sellmanb's Avatar
Car: '86 Berlinetta
Your 84 f-body flexplate and starter should have less teeth, thus why it's smaller than the Van's... I'm not sure if a van bellhousing will fit in a f-body though, I think I read something about the f-body needing a very small bellhousing to fit under the car.
Something to look up I guess.
... btw why would the mods have a field day w/ this topic?
Old May 16, 2005 | 02:36 PM
Zed'er's Avatar
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
[i]
... btw why would the mods have a field day w/ this topic? [/B]
Amount of pics....
Old May 18, 2005 | 02:53 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
The 700r4 transmission is a direct bolt up to both 305's it kinda looks like the same size I think, it was even the same length, the only difference is the style of tailshaft. I decided to go with the flexplate size that the TA came with. I would investigate further in hopes of a better balance, but I cant imagine why the bigger one would be much better.
Old May 22, 2005 | 10:01 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
this color looked better on the rattle can cap, oh well. Tranny is ready to go
Old May 22, 2005 | 10:03 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
305 heads now have 1.94 intakes, manley valves, comp springs and roller tip rockers
Old May 22, 2005 | 10:07 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
looks good, but .....OOPS!!!! I didnt notice that I put the top pulley on backwards till I saw this picture, I must be working to hard.
Does anyone think I will have clearence problems with these 1.52 rockers and stock valve covers?
Old May 22, 2005 | 10:24 PM
AsphaltAssalter's Avatar
Car: 92 Camaro
I would have done some unshrouding on the cylinder head chambers when those big valves were installed, looks like that's going to hurt the flow some.
Old May 22, 2005 | 11:12 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
I sure hope not.
My new cam gives .449 .456 lift so I didnt think that would be enough for shrouding.
Old May 23, 2005 | 06:29 AM
Car: 92 Camaro
That's even worse that you have a small cam, shrouding will be worse at low lift because the valve can't get away from the edge of the chamber at low lift. Look at this pic of a head that has had the valves unshrouded and you will see what I'm talking about, then look at your head.
Old May 23, 2005 | 10:48 AM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
Hmm, the machine shop did remove some chamber material around the side of the valve, I just thought they were sloppy while cutting the bigger seats. Did they do this to deshroud it? or just for clearance?
okfoz
Oct 13, 2015 02:19 PM
1MEAN92RS
Nov 17, 2002 08:12 PM
RICHRAD
Aug 17, 2002 11:02 PM
KlayBuRn
Car Audio
Jul 25, 2002 03:13 PM
Bort62
May 18, 2002 03:54 PM
