timing?
Old May 18, 2005 | 08:36 PM
355gta's Avatar
Car: 1989 pontiac firebird trans am gta
Engine: 355
Axle/Gears: 327:1 9 bolt
timing?
just posted a new message and forgot a big question. in the new car craft they bought the 91 ta. they said they adjusted the timing to 12-15 from the initial of 6 degrees. since the computer adjusts the advance, how would i go about doing this. is just like normal( unplug the connector, etc.) or what. i believe i might experience spark knock but i dont know.
Old May 19, 2005 | 12:24 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Yea, just unplug it an use a timing light. That seems really high though... really unnecessary to go that high, especially if you plan on starting the engine after its already hot.
Old May 19, 2005 | 04:04 PM
irocdaddy's Avatar
Car: 89 iroc,2012 eco 150,roadglide
Engine: zz4
Transmission: t56
UM, I am confused here.....
why would they move timing of the base 6 deg. if the ecm takes over after the motor starts?
Old May 19, 2005 | 05:11 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The ECM adds timing based off the manualy pre-set base value.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
