Engine Temp guage sending unit
Old May 19, 2005 | 04:48 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
I got a v-6 tpi camaro. I need to replace the sending unit for the temp to the gauge... but alll the auto parts stores have npo clue what im talking about.... In the haynes manuel it calls it just that the engine temp gauge sending unit. I dont know ehre i can get it since they dont knwo it... Advanced auto went through all their senser and nothing was right. I mean its a thrid gen tpi engine... Is it possible that this is a lost part? or is it called something else? or maybe its not a third gen engine? Im out of ideas please help
Old May 19, 2005 | 04:52 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
A V6 TPI? No such animal. That may be the problem there....
The V6 was either MPFI or carbed, depending on the year.
Old May 19, 2005 | 05:02 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
MPFI... w/e.. they dont ask that at the store.. they ask FI or carb
Old May 19, 2005 | 05:42 PM
sellmanb's Avatar
Car: '86 Berlinetta
Should be under Coolant Temperature Switch or something I think. I know the one that tells the computer what temp it is, is called the Coolant Temperature Sensor, but the gauge one has a different name that is at the tip of my tongue lol.
Old May 19, 2005 | 07:56 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
its not a switch.. we bought it and tried.. different connectors
Old May 19, 2005 | 11:16 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Temp Gauge Sender?
Old May 19, 2005 | 11:19 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
yup
Old May 19, 2005 | 11:23 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It's a temperature gauge sender, has nothing to do with the computer.
Old May 19, 2005 | 11:30 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
who said anythign about a comp?
Old May 19, 2005 | 11:35 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Nobody, I read sellmanb's post wrong.
That's what it's called, anyway. If they can't find it under that name then they most likely don't have it.
Old May 19, 2005 | 11:39 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
well... no one does then
Old May 19, 2005 | 11:42 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Have you tried the dealer?
Old May 19, 2005 | 11:46 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
not yet....
Old May 20, 2005 | 05:51 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Try www.partsamerica.com or www.autozone.com or www.napaonline.com
Get the part # and go buy it
They have it; just because the people behind the counter don't speak English or whatever, don't accept their stupidity
Old May 20, 2005 | 08:09 AM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
well advanced and oreillys helped me.. They spent like 2 hours looking through all thier sendors and switches to find the right one.. we checked every third gen camaro too. Since the enigne is a replacment
Old May 20, 2005 | 08:32 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
http://www.partsamerica.com/ProductD...pe=425&ptset=A
Here's the correct part #s, straight off partsamerica.com (Advance). Assuming a 91 6-cyl car. If the one you got was one of these numbers, it will work.
Doesn't matter whether the motor has been replaced or not.
Old May 20, 2005 | 09:23 AM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
its a two prong connecter... i think ima just go to the dealer
Old May 20, 2005 | 09:28 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The gauge doesn't use a 2-prong connector.
I just posted you the part #s you need. Like VIRTUALLY ALL temp gauge sending units, they're one-prong.
What color are the wires?
Old May 20, 2005 | 11:01 AM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
the one on my car is two.
Old May 20, 2005 | 11:06 AM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
a tannish color and a redish color
Old May 20, 2005 | 11:16 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That doesn't sound right.
Temp gauge is a single dark green wire.
The ECM's coolant temp sensor is black & yellow.
Tan & red sounds like the oil pressure switch for the fuel pump, or some such.
GM has been using a single dark green wire for the temp gauge (or idiot light, as the case may be) since the 50s, that I know of; maybe before that.
Where is this sensor you're trying to replace?
The temp gauge sensor should be either in the head, or in the intake manifold or water outlet; somewhere that it will be immeresd in coolant.
Old May 20, 2005 | 11:23 AM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
liek 2 inches away form the temp sensor
Old May 20, 2005 | 11:25 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Look around for something with a single blade (or mushroom style... same wire connector fits both) connector and a single dark green wire.
Does your gauge not work?
Old May 20, 2005 | 11:29 AM
Zed'er's Avatar
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
Probably a knock sensor or something.
Old May 20, 2005 | 11:32 AM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
no it doesnt... its rigged toi another gauge cuz the guy i bought it from is a retard.... its a two small blade connector
Old May 20, 2005 | 02:25 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Welll.... if you have a non-factory gauge, then there's a good chance that a factory sending unit won't work with it, regardless. It's certainly not very sensible to look up factory sending units, and then get mad at parts stores because the direct factory replacement they hand you isn't the right thing for your non-factory aftermarket gauge setup.
Rather than dink around with whatever the other gauge is, see if you can get your factory gauge to work. Try finding the dark green wire. If you short that wire to ground, your factory gauge should peg. Disconnect that wire, the factory gauge should sit on "cold". If you can make your gauge do that, then you need to put the right ending unit back in (the part #s I posted) and do away with the other thing.
I have no clue where the wire or the sending unit are; although I'd guess, if I was the guessing kind, that it would be on the left side of the engine somewhere. Either in the left head, or possibly in the intake manifold. But, you have a 6-cylinder, and I know absolutely nothing whatsoever about those except in the most general terms. I don't think I've ever even touched one in one of these cars, and I've seen only just a couple, ever, in anything (mostly people's S trucks, and all of those that I can recall have been carbed ones). I certainly haven't ever had one of these cars with a 6-cyl, or worked on one. Maybe somebody that knows about those can tell you more about where it is.
Old May 20, 2005 | 02:54 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
in the haynes repair manuel it shows where it is and what it is called.... i know what im talking about.. its the stock gauge im trying to get to work. it has a two prong connector.. i need the sensor that goes into the engine
Old May 20, 2005 | 03:35 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
OK... well, not alot I can do to try to help any more then.
Old May 20, 2005 | 04:35 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The factory temp gauge sender wire is a single green wire on all the thirgens as RB83L69 says. The oil pressure switch uses an orange/black and tan/white wire, IIRC. Where does the Haynes manual say the sender is?
Old May 20, 2005 | 04:56 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
kddy corner form the actual temp sensor, both are under the throttle
Old May 20, 2005 | 08:33 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You're talking about photo 8.6 on page 3-6? That photo shows a single wire connector in the tech's hand, and a single sutton terminal sensor threaded into the head behind the power steering reservoir. Whatever you're describing sounds like it's in the intake manifold.
The GM P/N for the sender should be 25037346. <img src="http://198.208.187.182/servlet/com.entigo.acdelcocatalog.servlet.ProcessImageServlet?languagecd=EN&countrycd=US&user=InternetUser&mfgname=&prodlinecd=&acpartnbr=25037346">
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Irocohio
Aug 12, 2015 08:03 AM
