ARP Lube
ARP Lube
Starting the 400 build today guys. Have splayed main caps and because of the angle of the caps the outside bolts screw into the water passage partially. So im using ARP lube on everything to get the correct torque yeild but will this cause coolant to flow past it and mix with my oil? Do i have to use a teflon type liquid or will the ARP lube keep the water out as well?
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
I would definately use the liquid teflon and just use the "standard" torque specs (only on the outer bolts though).
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
