Valve stuck open
Old May 22, 2005 | 10:09 AM
FlaCamaro91's Avatar
Valve stuck open
not sure what number it is. The 4th valve from the front on the passenger side is stuck open. I can't seem to ge the pushrod to sit right.
I first noticed a popping sound under higher rpms so I removed the valve cover and noticed that the valve wouldn't close. I removed the rocker and since then I can't get the pushrod to sit properly and now it makes the loud popping noise always.
Any help would be appreciated.
Old May 22, 2005 | 10:52 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
If you pull the rocker and the valve is still open, would probably mean the stem is stuck in the guide, as opposed to a lifter stuck up in it's bore. Best bet would be to pull the head(s).
Old May 22, 2005 | 03:09 PM
ede's Avatar
ede
or you could smack the stuck valve with a hammer and see what happens. use to stick valves all the time on new kart engines and all it took was a smack with a hammer and no more problems, not to say that you may not have a bigger problem than a stuck valve.
Cameeeero
Sep 18, 2015 04:00 PM
backtothe80s
Sep 5, 2015 12:39 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
lakeffect2
Aug 23, 2015 08:44 AM
