Is this 4-pin or 7-pin Ignition Control Module?
Old Jun 4, 2005 | 02:59 PM
Make's Avatar
Itīs ī84 Z-28 with auto trans and LG4 engine. I want to replace the coil, module, rotor and cap. I think they are original 21-year old parts.
Looking at the parts catalog there seems to be 4-pin and 7-pin modules so i went to see wich it had. But I didnīt get the rotor off. Are the 2 bolts on side holding it together?
Well anyway.. didnīt have right size sockets to remove them and didnīt want to break it either.
Can anyone tell from this picture wich is it?. On top it has the numbers "908 4002"
Old Jun 4, 2005 | 03:01 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
yeah the bolts are holdin it on, can't tell what ya have there as far as the ICM, the rotors in the way.
Old Jun 4, 2005 | 03:05 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Is that a vacuum advance can I see on there? If so, then it's a 4 pin module.
Old Jun 4, 2005 | 03:16 PM
Make's Avatar
Hereīs pic from another angle.
I didnīt see any vacuum lines come to it
Maybe i should buy the right socket (1/4" is it?) and make another trip to see wich is it, but at the moment the car is stored quite far from where i live.
Old Jun 4, 2005 | 03:35 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Ok, no vacuum advance on it, so no 4-pin module.
Old Jun 5, 2005 | 12:51 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Could be a 5.
Old Jun 5, 2005 | 08:48 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Here's the right one. Count them. http://www.partsamerica.com/ProductD...tnumber=D1961A
Old Jun 5, 2005 | 11:41 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
check to see what the price is for a new reman'd dist vs just buying the module. might be worth spending a few extra dollars and get a nice complete rebuilt unit.
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
TrevinE
Sep 14, 2015 03:20 PM
Jlanz55
Sep 6, 2015 03:05 PM
Jlanz55
Sep 6, 2015 02:35 PM
