Spark plug gap.........??
Car: 79 Camaro RS
Engine: 355, carb, alum heads, XE262
Transmission: TH350
ok I got the MSD stuff installed without a hitch and everything works fine. Although I have a question, I gapped my plugs to .040 and I think i should have gapped them a little more. If they are at .040 will this decrease my performance as opposed to say if they were gapped at .045 or .050, also what would you recommend as an appriate gap.
j.wolfe
_ ____ _
91 GTA L98
Best time: 14.389@95.49 (VMP)
"...Deception..." Brandon Sloan * ...wounds heal and chics dig scars...
j.wolfe
_ ____ _
91 GTA L98
Car: 1989 C4
Axle/Gears: 307
Gap it one of those things you can play with a bit and see what runs best for your setup.
.45 is whats posted on the tag for gap in my cars. So use .45 as a base line then move up.
SSC
SSC
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
