Quick help please...
Old Jun 17, 2005 | 09:24 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Simple question...
What type of grease or compound are you supposed to use when installing an HEI control module?
Thanks.
Old Jun 17, 2005 | 09:25 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Dielectric.
Old Jun 17, 2005 | 11:05 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
No. Dielectric has and may still work, however, it is not the correct product for this.
DG (dielectric grease) is so prevalent as the answer in the auto aftermarket and has caused enough problems that Ford allegedly sent out a TSB on it telling the techs not to use it with the TFI modules, but rather to use the proper thermal heat sink compound.
Yes DG comes packed with some of the ignition modules sold, but that doesn't make it the correct and/or best option, just the cheapest.
DG keeps moisture out of connections when used on both spark plugs and regular low voltage connections. When you use DG in a connection and slide or bolt the connectors together you make a metal to metal contact that carries the current. The DG seals out air and moisture at these contact points which prevents corrosion. It really wasn't meant to transfer heat.
The proper stuff, if you want to grab something from the parts store is a thermal heat sink compound, something like Wells part no. SL203.
hth
Old Jun 18, 2005 | 12:51 AM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Ok thanks.
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
